Question about Envision G22LWK 22" LCD Monitor
My Envision LCD Monitor screens turns gray once its power on. I have tried changing contrast will not work.
My Envision monitor screens turns gray once it is powered on. I have changed monitor to make sure its not the computer and I have also tried changing the contrast? Is there any way I can fix this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Apr 04, 2014
  • 84 Answers
SOURCE: envision en 9110 lcd
More than likely bad inverter board or power boards
Posted on Feb 11, 2008
SOURCE: Envision LCD EN-7100e Monitor "Input not supported
The problem was the resolution setup on the old crt monitor was not compatible with the new lcd monitor. I changed the resolution to one suggested/recommended by envision and the problem was solved.
Posted on Apr 24, 2008
SOURCE: Envision 17" LCD display will not stay on
Seems the N-Channel MOSFET switch in the power supply is the culprit. NTE does not list a replacement part for this, so a sub is necessary (any N-Channel 600V MOSFET in same TO220F case should suffice). I have to look one up for mine.
Posted on Mar 25, 2009
budmrtn
  • 11361 Answers
SOURCE: I usually leave my Envision G22LWk LCD on all the
Open up the set and look for bad caps, see saome examples of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 07, 2010
  • 732 Answers
SOURCE: I have a Envision EN-7100e monitor. Downloaded
catamount309, This is only a guess, but unit may have internal "switch-mode-power-supply"/"CCFL inverter" board problem. When screen goes BLACK, is it also BLANK? If you can see WIN-desktop with aid of bright flashlight 1 inch from screen, then SMPS is in partial shutdown mode. If you see nothing, then SMPS is in full shutdown. In either case, Technician will need to repair the SMPS/CCFL inverter board. If KNOWN GOOD monitor works with PC, then you know 7100e is bad. Do you know and understand how the new energy efficient screw-in curlie-Q light bulbs work? If the "electronic ballast circuit" not working, then it can't light-up the CCFL tubes on the reverse side of LCD panel then you see black. Do more reading in my fixya profile for more options open to you. Do your research first!! Hey, reading is free!!!
Will you fix or trade for new? 12fixlouie
Posted on Mar 08, 2010
Testimonial: "very helpful, seems to be right on. quick response. thank you very much"
Fine tuning the contrast & darkness
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
May 29, 2014 | Envision Peripherals 19" envision g917w1...
Tip
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
The power went out while i was using my computer, and after i turned it back on the monitor screen was extremely bright. im trying to adjust the brightness/contrast, but none of the monitor keys are...
I wonder if the power just went out or if you had a surge then went out. The settings are stored in a nonvolitile ram inside so you can't just unplug it and get it to reset. The bit about the buttons no longer working sounds like a power surge damaged the board. Not sure what we could do if we had it in the shop. And it would probably be cheaper to buy a new one than what the repair bill would come to.
To work around this you can adjust the contrast setting in windows (assuming thats what you are using). You need to get into display properties. It may be also under the display or video control manager if your video card uses one. I have a ATI on this machine and I have to open CCC or catalyst Control Center to get at what we need. Usually you can just right clik on a blank place on the desktop and the select properties which brings up the display stuff. Then click the settings tab, then advanced (lower right) which open a new window and then click on the Color tab. This will have a few sliders to adjust the color as well as brightness and contrast. Once you find a setting that works hit apply and you are done. If the monitor gets sorted out or replaced then you just need to go back in there and hit reset and the sliders go back to the normal positions.
Aug 12, 2010 | Envision 19" Widescreen Flat Panel LCD...
Mar 07, 2010 | Envision EN-7100e 17" Flat Panel LCD...
Monitor issue
Just sounds like the monitor cable is loose or bad or the input mode on the monitor is set wrong - set it to auto or step through the modes.
Aug 10, 2009 | Envision H191W Monitor
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Envision en 9110 lcd
Nov 06, 2007 | Envision EN 9110 19" Flat Panel LCD...
Help
If the monitor was dropped, most likely you damaged the internal components that provide the picture, whether LCD or CRT. Try connecting it to another computer. If this doesn't work, check the monitor's display settings or operating system display settings for contrast or brightness. NEVER open up the monitor, because there is a high voltage capacitor that stores voltage even when the monitor is off and could kill you if it discharges.
Jun 11, 2007 | Envision EN-7220 17" Flat Panel LCD...
Envision G22LWK 22" LCD Monitor Logo
64 people viewed this question
Top Envision Computers & Internet Experts
Cleverer2
Steve
Martin Murray
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
