Question about Vehicle Parts & Accessories
4L80E tranny wont shift
I have a chevy c3500 with a 4L80E tranny. recently it started shifting funny. one day it wouldnt shift out of (i think 2nd) and my max speed was 35 without winding out tranny. drove it later that day and it wad fine. this happened about six other times and after turning truck off it corrected itself. now that isnt working and it wont shift. any suggestions anyone?
  • 3 Answers
First, what's the mileage and what year? If this is a serviceable transmission and it doesn"t Have a bunch of miles sense the last service try a full fluid flush. Sounds like a dirty valve body and dirty servos. full flush may fix it. a full service shop should be able to do the flush. They will also do some preliminary tests to get a better diagnosis based on mileage and service history. If it's got 70-80k miles since last service, an o/haul may be needed. A full flush is not the typical drain and fill that most shops do as regular maintenance. Find a shop with a good reputation and good customer satisfaction. Late model transmissions are more complicated than the engine and have tighter tolerances.
Posted on Apr 21, 2014
2 Suggested Answers
  • 80 Answers
SOURCE: shifting prob
Your sinchronizers are worn. They might need replacement. A temporary fix wich can help shifting is replacing your actual gearbox oil with a synthetic lubricant. These lubricants help reducin noise and make shifting softer.
Posted on Nov 13, 2013
Swapped a 350 in 91 Chevy 3500.To a 305 motor.now tranny acting up.has 2nd 3rd. Changed fluid & filter.Now nothing.It want slip or anything.rebuild time? electronic ploblem? (shift solenoid)it's 4l80e
Sounds like electronic problem, if the tranny worked ok before the swap. Are you sure the converter is installed correctly? Also double check the shift linkage
May 02, 2015 | Cars & Trucks
4L80E tranny problem shifting
I would replace transmition fluid first and maybe change filter in auto box , this is cheapest first option .
Mar 27, 2014 | Vehicle Parts & Accessories
1988 chevy 4x4 k1500 auto tranny wont shift into 2nd, 3rd etc
Check the sensors on the transmission. May just be corrosion on the sensors or it may be a faulty sensor. Also, the torque converter bearing may have went bad due to the running it on low transmission fluid.
Feb 23, 2014 | Cars & Trucks
1992 chevy 3500 wont shift unless under hard acceleration
there is a transmission sensor on the top of your motor by the intake. it senses the accelerator or motor rpm's and tells the ****** to shift. its about 30.00 and easy to change. get it at any auto parts store.
Aug 26, 2012 | 1992 Chevrolet C/K 3500
The transmission, 4L80E, will not shift out of first, abs light is on, no speedometer, no heat or a/c, all at the same time, then all went back to normal with gerky trans shifting, then all went to ma
i have a chevy c3500 with a 4L80E tranny. recently it started shifting funny. one day it wouldnt shift out of (i think 2nd) and my max speed was 35 without winding out tranny. drove it later that day and it wad fine. this happened about six other times and after turning truck off it corrected itself. now that isnt working and it wont shift. any suggestions anyone?
Feb 22, 2012 | 1994 Chevrolet Sportvan G30
94 chevy k1500 wont shift past 2nd gear.
its possible the shifters linkage is bent
Mar 17, 2010 | 1994 Chevrolet K1500
Replaced TBI with Carburator, 4L80E wont shift
all u need to do is get a holley electric choke carb model i think is 4150 or 4160 and get the tps sensor adapter for it it is around $110 and the carb is around $290 ur trans shifts off of the tps. all the other sensors are useless. i had that same problem with my 94 silverado.
Nov 10, 2009 | 1991 GMC Suburban
4l80e shifting problems
SOUNDS LIKE SHIFTING SOLENOIDS ON VALVE BODY INSIDE TRANNY OR IT COULD BE BUFFER THAT COMUICATES WITH TRANNY OR OBC BEST TO LET TRANNY GUYS HAVE A LOOK @ THIS ONE RATHER THAN SPEND A LOT OF MONEY WITH LITTLE RESULTS
Nov 23, 2008 | 1993 GMC Sierra C3500
Vehicle Parts & Accessories Logo
85 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
