Question about Koldfront Portable Counter Top Ice Maker White
Ice maker wont make ice
Power went out wont make ice
Power went out freezer won't make ice in ice maker
Hey friend, thanks for your inquiry!
Normally, if power is not being received by your Frigidaire refrigerator it will not produce ice within the icemaker. Now once power has been restored it could take up to 24 hours to maintain temperature and start producing ice. If the power went out it is possible that the icemaker could have shorted or the water valve could have went out. I hope this information has been insightful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
Ice maker wont work
The ice maker gets its water from the filter too. If there is NO water getting to the ice maker then look at the solenoid that lets the water into the ice maker. If water seems to be frozen to the underside of the Ice maker, take the unit out and allow it to dry before putting it back in.
Jan 14, 2014 | Samsung RS267TDBP Side by Side...
Ge profile PFSF6PKXEWW AFTER POWER OUTAGE ICE MAKER DOESMN'T WORK
If the ice maker is not filling with water after dropping the last harvest of ice cubes it will indicate a defective WR57X10091 Water Inlet Valve If you would like to try self diagnostics on your model click HERE and go to page 78, I will be here should you have questions, Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
Icemaker
this is a test, if its a new er model, turn maker switch off for 15 seconds,turn on move the flap arm below the maker bak and forth 3 times waite 3 min, this should reset maker
May 07, 2010 | Maytag MSD2651 HE Side by Side...
I HAVE A SIDE BY SIDE KENMORE FRIDGE, 10YRS OLD. NEVER HAD PROBLEM WITH ICE MAKER UNTIL A COUPLE OF DAYS THE POWER WENT OUT AND WHEN IT FINALLY CAME BACK ON, NO WATER OR VERY LITTLE WAS GETTING TO ICE...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jan 01, 2010 | Refrigerators
Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Mar 31, 2009 | Samsung RS2578BB Side by Side Refrigerator
Koldfront Portable Counter Top Ice Maker White Logo
41 people viewed this question
Top Koldfront Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Koldfront Kitchen Appliances - Other Expert? Answer questions, earn points and help others
