Question about Water Heaters
Rheem 22v50f1 Does this model have a back flow preventer? From time to time I'll get low hot water flow rate. It seems to solve itself when the city water pressure is increased for heavy morning consumption.
  • Water Heaters Master
  • 5,089 Answers
Backflow preventer is not part of water heater:
http://waterheatertimer.org/images/Watts-water-heater-parts.jpg
Water heater might have heat trap nipples that get clogged... but other issues have to be eliminated:
http://waterheatertimer.org/Low-hot-water-pressure.html
Gene h
Posted on Mar 29, 2014
After city changed water meter the water is not consistently hot.
There are two things to check. First, check the inlet water filter on the heater. The changing of the meter may have introduced debris in the line and partially clogged the filter, causing flow issues that affect turn-on/turn-off of the unit. Also, the new meter may have changed the water pressure/flow rate into the house, If the filter is not the problem, have the inlet water pressure/flow rate checked. If it is too low, there may be some adjustment that can be made, or the city may have to replace the meter with a different unit.
Dec 01, 2015 | Eemax EX280T2T Series 3 Whole House...
Pilot light on my rheem water heater goes out frequently, model # 22v50f1,about 4-5 years old
There are many reasons why pilot light can go out, from bad thermocouple to low air supply to dirty combustion parts, clogged orifice, low gas pressure, etc.
Copy following link and read information available for troubleshooting pilot outage.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Jul 25, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I HAVE A 50 GALLON 5YR OLD RICHMOND HOT WATER TANK SOMETIMES YOU TURN ON HOT WATER AND IT RUNS FINE.THEN ALLOF A SUDDEN THE WATER STOPS AND PIPES BANG.WE HAVE 44PSI COMING IN FROM CITY
What you're describing is "water hammer". This problem, left unchecked, can cause big problems for your home's plumbing. Water hammer is result of quickly shutting off the flow of water in your home. The faster the rate of water flowing when it is rapidly shut off can result in very loud banging. The banging is caused by the pipes shaking in the walls, ceilings and any place they aren't secured. This repeated shaking causes soldered and glued joints to weaken and eventually fail. The most common sources for water hammer are toilets and wash machines, but even quickly shutting off a faucet can cause it too.
An short article about water hammer is here. Below is a link to images of products designed to arrest water hammer and associated noise.
Please rate this reply - I hope this helps!
Dec 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Gron d fos pump hot to touch.no hot water in
Your circ pump is burnt out which is causing your hot water to not flow adequately to your fixtures.
Feb 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Does the Rheem Fury model 22V50F1 qualify for an energy tax credit?
Unfortunately, no... According to the Rheem website, the Rheem Fury model 22V50F1 has an energy factor of 0.58:
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
In order to qualify for the credit, the energy factor must be 0.82 or greater...
Jan 31, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
My outlet(HOT tube is plugged. can i solve this?
Replace your tank. You are probably just days from the bottom of the tank falling out, which, my friend, is not a pretty sight.
Call the plumber if you are not able to use a soldering torch and pipe cutting tools.
Jan 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
We have a Rheem PowerVent, 36,000 water heater for nine yrs now. This is the 5th time we seem to have a problem. We only get about a 5 minute hot shower and it turns cold. Is this water heater a...
Is the water heater in a basement or an area thats cold? A water heater jacket may help.
If not ,try setting the heat up a little higher on it until you have more then a 5 min hot shower.
May pay you to get a 100 gallon heater.
Jan 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I cannot find the booklet on the rheem's hot water heater to adjust the water temp. Model # 42VP50Fu. Thanks We just moved into this home and would like to lower the temperature. Bill and Arlene
Hi,Bill and Arlene,in front of the unit there is a square box,on that is a dial,turn it to the right for more and left for less. please rate my answer.
Jul 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
70 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
