Question about Scotsman Ice Maker 600LB CM3 30inW Commercial Cubed Machine
I have a scotsman cme656 the bin sensors where bad, bought a new set install sensors. They would no sense ice dropping , put my hand in shoot light blinks, only when my hand is within 1" or 2" from le
New ice bin sensors , new controller , ice bin sensors will no detect falling ice
    Novelist:
  • 187 Answers
Check the condition of the connection for the sensors. If corroded or not connecting properly, the sensor has limitted range for ice sensing.
Posted on Sep 30, 2014
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 102 Answers
SOURCE: Brand new Scotsman DCE33 ice maker melts ice
Check that the condenser is clean, the plastic sheet is hanging over the opening and trhat both spray nozzles are in place.
Posted on Aug 06, 2009
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
  • 112 Answers
SOURCE: On our Scotsman cm3 the
These units have a real problem with the bin controls. I can't begin to tell you how bad. There are two - for lack of a better term - paddles - that are basically just pushed into the left and right side of the drop area that have small lenses in them with a low level beam that when broken indicates a full bin. You have to reach in from under the bin opening and feel to the left and right, pull the paddles toward the middle and there should be enough slack on the wires to get a good hold of them and clean the lenses with a Q-tip soaked in grapefruit juice. Pop them back in and try them - if that doesn't work (and sorry but most of the time it doesn't) then they will have to be replaced.
Posted on Dec 11, 2010
donitarenzo7
  • 27 Answers
SOURCE: Scotsman DCE33A-1WB not draining
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Posted on Oct 31, 2012
Hello I have a scotsman cme656 , the bin senrs where bad I replace them with new ones 3 times. When the bin level sensors are in place the will blink only 2" away from left bin full sensor , any furth
When replacing the senor the red n black one the wire harness needs to be new as well you can check the transmitter with your cell phone camera both eyes should glow when plugged in
Apr 04, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Scotsman CME506 will not stop making ice
Replace the bin control sensor set of two. Part number 11-0540-21. The bin control sensor is not sensing that the bin is full.
Aug 03, 2013 | Kitchen Appliances - Others
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do I fix the max harvest time shutdown
The ice sensors are not sensing the ice fall.Wave your hand in front of them the bin full light should blink.If it doesnt clean eyes and conectors.If it still doesnt blink change them they are bad.
May 21, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Apr 15, 2010 | Scotsman Cooled Modular Contour Cuber Air...
Where are the bin full sensors located for cme306as-1c bin full light on will not make ice.
It is a set of eyes located in the very back right and left hand side where the ice drops into the bin. Take some ice machine cleaner and wipe down the eyes. You should be able to pull the holders out to get to them better.
Jan 30, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My binsensor lingh is on but my bin is not full so my ice machine
I see you already said you bin sensor light was on. The drop door has a metal tab that waves over a sensor as it opens, if that part when it closes does not tell the board that door is shut the the board thinks the bin is full. I know you already know that but until I can talk to Scotsman on the phone or review their service manual for your model. One good thing about Scotsman is they are very helpful to their customers. Unless the machine is obsolete.
Apr 23, 2009 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman cme506
i service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
Apr 14, 2009 | Scotsman Cooled Modular Contour Cuber...
Refrigerators Logo
158 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
