Question about Vision HDV-42P2 Television
Tiny v shaped crack in screen
Worked fine with crack & had 5 lines top to bottom far right side but was hot, cuz never was turned off
    Top Expert:
  • Vision Master
  • 75,320 Answers
No other remedy than replace the display panel with a new one. Gopakumar Gopalan Google
Posted on Mar 28, 2014
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
On my Toshiba Tecra when in GoogleChrome the the image on the screen is 25mm too far to the right. This makes it impossible to use the up/down key at the top right of the screen and the enlarge and...
Have you tried double clicking on the bar right at the top of the screen next to the minimize, maximise, close buttons? By double clicking in this area it'll change the size/shape of the browser screen, you can then reposition the window to the top left of your screen and then click and drag the bottom right hand side of his window once the cursor turns into a double headed arrow.
Apr 18, 2011 | Computers & Internet
Hello, I am putting in a grohe 35016 rough in valve. My shower has cold/hot 1/2" pex line coming in and i need to have one line going up into the ceiling for a rain shower head and another line going...
Hook the cold line up to right side and hot to left. Run line to wall shower off the top and use two 90 degree elbows with a short length of pipe turned slightly to the side of the line to wall shower. Run pipe up to ceiling height then 90 over and down to location you want forrain shower head. Hope I made this clear as I know sometimes I don't explain things well. Thank you.
Feb 04, 2011 | Home
E machines flat computer screen began blinking and having colored lines going through it after turning black. By odd mishap I realized when I pressed on the screen it stopped doing that. That has been...
By the way, is it an LCD screen? I guess so. LCDs have small IC's either on the lower portion or in the left side of the screen. When these become loose, the tendency is to have vertical or horizontal lines on the screen. Hot air blower might solve the problem. But most will not. Better claim warranty or replace the unit.
Dec 07, 2009 | E-Machines eMachines Desktop PC
Cracked screen
If the plastic cover is cracked but the LCD is fine, the fix is very different. In some ways it's actually harder than replacing the LCD, which is simply connected by a ribbon cable. One challenge for you is that, unlike the LCD, which is available as a replacement part (on Ebay - about $25), there is no direct replacement available for the plastic covering. You will need to pick up another 880 that is being sold for parts and then salvage the plastic screen from there. I'm not sure I can actually describe the replacement procedure to you without pictures but here is the general idea:
First, you need to open the remote so that you can work with the top half. To open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the ****-shell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Now, take the bottom of the remote that is holding the logic board and put it aside. You will only need to work on the top half of the ****-shell case. Ok, now looking at the face, there are 4 pieces of silver trim that are locking the plastic screen into the case, two on each side; the piece directly above the Mute button and the Prev button (they look like unmarked softkey buttons), and the two thin elongated pieces at the top on either side. To remove these pieces, you need to turn the top half of the casing over so that you are looking at the underneath at the area of these 4 trim pieces. If you look carefully, you can see that there are very tiny posts covered with glue that are holding in these pieces. You need to forcefully, but carefully scrape the glue off and try to push the trim pieces out from the back. Try to do this is carefully as possible, since the surrounding plastic is delicate. Once you pop these pieces off, turn the top half back right-side up. Now the only thing holding the screen down is a kind of rubber cement around the perimeter. To remove your cracked screen, you can pull it off from the bottom without worrying too much. However, be very careful when trying to get your replacement screen off of the salvage remote! The screen must be pried up gently and slowly from the bottom. If you use too much force, you risk cracking the screen as you pry it up. If you wind up scraping some of the black paint on the screen's perimeter, you can use a permenent marker to color it. Back on your good remote, remove as much of the cement as you can and lay down some double-stick tape (a glue stick may work also) and lay the new screen down so it is aligned perfectly in the space. Then attach the trim pieces and use some epoxy on the underside to affix them in place. Re-assemble your remote and it should be as good as new. Good Luck!
Sep 06, 2009 | Logitech Harmony 880 LCD Remote Control
My Dsi has a crack that you can only see when it is on
It can be repaired, however it can not be rpaired at home. If you were to send it in it would cost you about the same to buy a used one because this is what Nintendo would consider cosmetic damage. They don't tell you that the screens are one of the first things to break.
Jun 25, 2009 | Nintendo DSi Black Console
Lines on LCD
Once you see lines on the lcd that defitinely means the lcd is bad. As far as the board to the lcd, that would be behind it but with all the delicate tiny IC's on it, its would be near to impossible to troubleshoot it and start replacing components cause its done by machine and the legs of the IC's have match up perfectly with where your going to solder it into place. Inverter is good, when ineverters go bad its either you get a dim screen, weird colors, or even a white screen. My suggestion, definitely get a new lcd put in there since your getting lines in the lcd. Also your lcd cable could be flaky as well but those are cheap so getting one of those isn't a problem. Get those two things replaced and your laptop should work like new.
Jun 13, 2009 | Toshiba Portege M100 Notebook
Spring w/2 tiny rollers loose
On my i455 all the rear slots are occupied. The front only has 2,5,7, 8 occupied. It works fine that way. I think the rear is more critical than the front to proper paper feeding. Good luck
Jan 16, 2007 | Canon i 450 InkJet Printer
Open Questions:
Televison & Video Logo
16 people viewed this question
Top Vision Televison & Video Experts
D. E. Hev
shaun taylor
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
