Question about Dryers
Hunter-ceiling-fan light wont work
Our hunter Douglas ceiling fan/ light was installed fall of 2012. A light bulb burned out. Now the light doesn't work at all but the fan does. No remote, just a wall switch. Any suggestions?
    Problem Solver:
  • 7 Answers
New fans come equipped with limiters built into the control cup. This is to prevent overloading of the sockets. Most light kits come with 40 watt bulbs these days so if you have replaced even one burned out bulb with anything higher than a 40 watt bulb the limiter will kick in and shut off your light. Also try switching to a 130 volt 40 watt candleabra bulb as opposed to the 120 volt, sometimes this helps.
Posted on Jan 04, 2015
    Genius:
  • 1,617 Answers
Make sure your contact in the socket is touching the bulb.
Posted on Mar 30, 2014
  • Randy Bower Feb 25, 2015
    make sure the bulb you are replacing it with is a good bulb,just because it might be new doesn't mean it is a good one
2 Suggested Answers
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
Posted on Dec 24, 2009
The ceiling light on my hunter will notcome on using the remote
The receiver may not be functioning, the bulbs can be burned out or the wire going to the lights can be disconnected.
Oct 21, 2014 | Hunter Sontera 52" Ceiling Fan with...
Hunter fan light fail
It has a defective switch or burned out bulb.
Jan 03, 2014 | Hunter 52" Ceiling Fan With Light And...
Light blew on ceiling fan, now the entire fan won't turn on, nor will the new light bulb turn on
Many of the newer light bulbs won't screw all the way down so you have to stick your finger in the sockets and bend the bottom tab up so that the bulb will touch it. Most ceiling fan installs i find that people don't put the marrettes on correctly and the wires fall out after the fan is up.
Oct 31, 2013 | Hunter 23852 Classic Original Ceiling Fan
Hunter douglas fan
Try changing the frequencies in the receiver & transmitter. If that doesn't work, you probably need a new receiver.
Oct 01, 2013 | Dryers
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
I have Hunter ceiling fan / light. I installed it. It worked fine for a little while, than one bulb blew out, then a second bulb blew out, now none work. Yes I repaced all the bulbs, still don't w
I would check with a voltmeter if you can safely to verify power at the light socket using an adapter to a plug in it. If you can not do that, with power off you may want to make sure that the socket contacts are good and clean. Sometimes they can become tarnished badly.
Oct 10, 2012 | Hunter 23852 Classic Original Ceiling Fan
Where do I find a new glass sconce for the light fixture fixture for a hunter douglas ceiling fan # 22434 (studio series) ?
there is a store where I live its called The Light House it is in Newark Ohio and they sell anything that has to do with lights...they might have what you are seeking
Sep 25, 2009 | Hunter 22434 Sontera White Ceiling Fan
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Oct 30, 2008 | Dryers
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
322 people viewed this question
Top Dryers Experts
