Question about Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Spa n a box impellar not spinning
Cant get impellar to spin
    Top Expert:
  • Comfort Line Master
  • 8,152 Answers
Bad recirculation pump or pump that wont spin
Posted on Jan 06, 2018
Why is the motor roaring ? is it rubing on housing or a bearing ?
It may not be you motor, but the sound of some item caught in the impellar, which is the part that causes suction. It is usually located in the upper housing, and can be accessed fairly easily. Unscrew any visible screws,(usually phillips type) and carefully lift housing off. This should expose the impellar. If debris is present, remove it.
But also check for possibly broken fins on the impellar itself. Sometimes items like coins, or nails etc, will get picked up accidentally, then spin around in the impellar housing, only to break a fin or two trying to move on. If this has happened, replace the impellar.
Dec 22, 2015 | Hoover UH70105 WindTunnel TSeries Bagless...
I am in Australia, and my 2HP aquaflow pump XP2 (model 06615168-1) hums on start up and eventually clicks off without pumping. The impellar and the shaft spin freely when I turn the shaft .What could the...
The Aquaflow pumps were the old workhorses and I still see some here in the USA that have been working for over 20 years. The first thing to do is see if the impeller turns freely just with your fingers. You may either take the lid of and stick a finger in the hole in the pot going toward the motor and try to spin the impeller, or on this pump you can reach the motor shaft through the holes in the motor mounting bracket. If the impeller spins freely, you most likely have a blown or open motor start capacitor. This is located under the little dome looking cap on top of the motor. At the very worst you would need to replace the entire motor but the pump should still be OK. This pump uses a keyed shaft motor and you need a long hex wrench to loosen the 3 set screws on the shaft extension. Not the easiest pump to work on but not rocket science either. Hope this helps.
Sep 02, 2011 | Aqua Pool & Spa
How do I remove impeller from motor? Is there bolt or does it screw off? It appears head of bolt is sheared off.
The impellar spins off counterclockwise on most pumps. The hard parts are holding the motor shaft from rotating and finding a way to grip the impellar.
Gary
Jul 24, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
2001 dodge durango 4.7L SLT ..overheating..replaced electric fan ..coolant temp switch ..clutch on other fan...thermostat...filler tube ..radiator cap..burped system ..no signs of head gasket blown..and...
Well the only thing you haven't replaced is the water pump. The impellar can dislogde from the shaft or completely disinerate. this is not common but I have seen it. Mostly the impellar spinning on the shaft. this is one of those jobs you just have to take it apart and see. No way to check it that I know of.
Jun 16, 2011 | Dodge Durango Cars & Trucks
Cant get lower unit loose from the shaft on 2004 25 h.p. merc 2 stroke. need to replace impeller
There is a small plate on the side of the leg.Put motor in N and undo the plate.Inside is the gearchange linkage.It needs to be undone to drop the g/box.That's after you have undone all the other bolts:)
Make sure you put the impellar in,in the correct spin direction.The lobes facing the correct way.
Hope this helps
Apr 07, 2011 | Boating
1 hp hayward pump and can get impellar off
Power off - lock the shaft at the end where the electrical is hooked up. Spin the impeller off counter-clockwise.
John
Sep 06, 2010 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Ihave a hayward 1hp inground pool pump and can not get the impellar off
John
Sep 06, 2010 | Hayward Pool & Spa
Motor humming will not turn
You can undo the bolts that are holding the motor to the pump. That will let you spin the impellar of the pump .. Please withdraw it slowly and observe how the extra pieces fall out because if you get them in wrong the pump will not work correctly, While you have it apart , try and spin the impellar and switch the motor on , seeing if it will run if you hand start it .. if it will not run , then you probably need a new motor .. Most pool shops can test the motor for you to confirm that .
Please Vote !
Jun 05, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White  Logo
122 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
