Question about Canon PIXMA iP90v Printer
Printer will not print.
It won't print. After warming up, the green light alternates with the orange light. But it will not print. I tried turning it off and disconnecting the power cords for a few minutes, then replacing them and plugging them in and turning it on with no different results.
  • 1 more comment
  • Jack Wilson
    Jack Wilson Mar 29, 2014
    The printer will send a blank sheet through and then stop. So there is not an obstruction to the paper feed. The printer just won't print after the first sheet goes through.
  •  Andrew Henderson
    Andrew Henderson Mar 30, 2014
    Is the flashing in a sequence like two or three orange to one green, or is there a number of flashes followed by a pause then repeating. The sequence should tell us what the fault is. Andrew
  • Roger Hewett
    Roger Hewett May 14, 2014
    It is solid green as when the job is completed.
    Novelist:
  • Canon Expert
  • 241 Answers
Fixing annoying little issues with these machines is difficult due to the compact design. I would hazard a guess that there is either a paper jam due to a paper fragment or foreign object obstructing the paper feed, or there is a fragment inside obstructing the printhead. To remove the first - turn it upside down and give a few GENTLE whacks on the bum. If anything substantial falls out, try printing. To tackle the second open the cover and let the printhead come to centre (you should take it off battery for this), then check each end of the cavity looking for a black ink soaked peice of paper. If you find one, remove it and go looking again. If neither approach works for you, try carefully feeding a strip of light card at intervals through the paper path, this will help locate anything caught in the feed roller. Good Luck.
Posted on Mar 28, 2014
Will not print
the sequence that the lights flash is how the error codes are given. Please count the sequence of flashes and re-post
Mar 27, 2014 | Canon PIXMA iP90v Printer
Mp220 absorber full check printer 5b00
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
Times LED Function Remarks
0 times Green Power off When the print head is not installed, the carriage
returns and locks in the home position.
1 time Orange Service test print See APPENDIX 1, SERVICE TEST PRINT.
2 times Green EEPROM information print See APPENDIX 2, EEPROM INFORMATION
PRINT.
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting
5 times Orange Destination settings Proceed to the step 5), and follow the
Destination settings procedures.
6 times Green Print head deep cleaning
7 times Green CD-R test print Not used in servicing.
8 times Orange CD-R print position correction
(horizontal)
9 times Green CD-R print position correction
(vertical)
10 times
or more
Return to the menu selection
Feb 05, 2014 | Canon PIXMA iP3300 InkJet Photo Printer
Flashing green orange lights
There is many reasons for that,
are you printing any thing???
Just restart the printed and see if lights turned off....
Jan 20, 2014 | Canon PIXMA iP4300 InkJet Photo Printer
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
Canon IP 3000 - ink absorber full
<Service mode operation procedures>
is selectable.)
Power button.)
PRINT.
Jul 02, 2010 | Canon PIXMA iP1300 Printer
My canon ip90 does not print, continue to get 5100 error msg
you can try this method to reset the error..
First close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.), then while holding the Power button, release the Resume/Cancel button but do not release the Power button.
While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange. During initialization, the LED blinks in green. When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. Pls note each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.
Then press the Power button, the LED lights in green, and the
selected function is performed. When the operation completes, the printer returns to the menu selection mode automatically. Last just power off then back on and test.
May 28, 2010 | Canon PIXMA iP90 InkJet Printer
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma mp-610
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
6) Power off then back on and test.
Jul 19, 2009 | Office Equipment & Supplies
My printer ink absober was full. my printer display e27 code. what can i do?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-9
Apr 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  iP90v Printer Logo
51 people viewed this question
old marine
old marine
