Question about Sony Playstation 3 (PS3) Console
Playtation is not reading my games/discs
When i start up my playstation 3 i enter a disk and there is no disc icon allowing me to start the game. i have also put auto play on but the problem still persists. i have also occasionally while turning off my ps3 from the switch at the bk got a yellow light however i can start up the ps3 fine. plz help
Lenses have a problem
Posted on Jun 15, 2009
  • meeri63 Jun 15, 2009
    lenses have a problem
How do I take out the NBA 2K10 PLAYSTATION 2 DISK WHEN i GOES TO THE MAIN MENU SCREEN
On the main menu there should be a tab called games. scroll down or up to find the game cd icon. when over the game cd icon press TRIANGLE over it and a side menu should pop out on the right side of your screen. This menu should say -Start -Internet Search -Eject Disc -About this game -Information Select Eject Disc and your disc should come out of your system
Sep 17, 2010 | 2K Games Video Game Consoles & Games
When I start loading a game or video the playstation sayds video or game can not be played (error 8002997F)
This error is related to an issue reading the BluRay Disc, you might try the following:
  1. Ensure that the latest system software update is installed on your PlayStation 3 system.
  2. Check the disc for scratches and dirt.
  3. Check that the disc is compatible with your PlayStation 3 system.
  4. Make sure that this is not only happening with one specific game, if so, the disc might be the issue.
  5. Try the disc in another PS3 system if you have one available to discard the possibility of a faulty disc.
Hope this helps.
PlayStation 3 system cannot read the disc
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
The game doesn't start.
Check your settings to see if the auto start feature is turned on or not. Also, how long have you let the player continue to attempt to read the disc, maybe try waiting a little longer if you haven't already. Sometimes the Playstation takes a while to load and read disc's. Hope you find this of some help, I hope that it's not an issue where you need to replace the disc drive itself. Try setting it to auto start the disc and see if that helps first. If this doesn't help right me back and I will try to assist you further.
Feb 16, 2010 | Sony Playstation 3 (PS3) Console
Ps 3 wont load discs and the disc icon doesnt show on the menu when a disc is inserted
i mostly think the laser to read the disk is broken you need a new one to work agin
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Playstaion 3 games wont load how can it be fixed. the clock (loading icon) stops. no errors appear no disk shows up.
listen for the disc to start spinning
if the disc spinns then its prolly just a dirty laser lens and if it doesnt spin could be a bad laser i doubt its the blu ray logic boad cause the ones i have seen that were bad the disk reading icon never stops, this has also happened on broken lenses where it never stops. ussually if it stops its bad motor or dirty lense.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont read any games, dvds or cds
I have the same problem. My PS3 stopped reading any bluray discs. The spinning circle in the top right corner will come on for a few seconds when a disc is inserted, but then nothing. I found a work-around to get it to read discs though. You have to have a bluray disc in the drive (game or movie) and start a downloaded game or Playstation Home. Once the game or Home loads, hit the PS button on the controller. The crossbar menu will pull up and you will notice the disc icon will (magically) pop up. Click the quit game icon. Once you are out of the downloaded game or Home the disc icon will still be there. You can then load the game or disc. The icon will remain there until you eject the disc, so you will have to repeat this every time you want to load a game. Although this is a workaround to prevent Sony from gouging you for $150+, this is still not a fix. A fix would be for Sony to admit they have a money making firmware problem and fix it. This fix will only work if you don't have an actual hardware failure (which I apparently don't). I think a class action lawsuit is in order for everyone that has this problem and especially for those who have shelled out the money to fix something that is firmware related. I'm sure Sony will only fix the firmware to make this workaround not work anymore so as not to lose their little cash flow scheme.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Disc read error
Disc Read Error generally means that the game disk cannot be read by your console.
Reasons for Disc Read Error
1. Disk surface scratched or smudged.
2. Disk surface dirty.
3. Lens surface dirty.
Here is what you can try doing.
1. Check the game disc for any scratches or smudges on the surface of the game disc, try to clean them off by using a non-abrasive cotton cloth.
2. If the PS2 console is lying down, please set the console to on its side or if it's on its side set it to flat position, restart the console and then try game again. Always ensure the PlayStation 2 is in a cool, well ventilated place.
3. Remove and reinsert the Memory card of your PS2, restart the console then try running the game again.
Other troubleshooting that you can try.
Change the Disc speed of the PS2 DVD and then try again.
Start the PS2 with no disc in a drive. Press the "triangle" button on the controller.
Use the up and down buttons on the controller to select "Playstation Driver” and press the "triangle" button on the controller.
Select Disc speed. If it is set to "Fast," select "Standard"; if it is set to "Standard", select "Fast" and press the "X" button on the controller. Press the "O" button on the controller. Insert the game disc and restart the PS2. Try running the game again.
Turn the Diagnosis On for PlayStation2 to auto detect the best settings.
From the Browser and System Configuration menu. Press the triangle button to select Version. Highlight the Console from the list and press the triangle button - this accesses the next menu option. The Diagnosis will be highlighted. Press the X button to access the options available. Highlight "ON" and press the X button to affect the change. Restart the console and try the game again.
If the above steps does do not solve the error then you would probably have to replace the disc.
Note: If you are using the Slim version of PS2 make sure that the console is properly ventilated and that it should always be in the standing position, as the slim version of PS2 no fan or any other cooling unit unlike the normal PS2.
Oct 13, 2008 | Video Game Consoles & Games
PS3 having trouble reading game discs!!!
hey guys. the problem is that the blue ray reader is some how broken and it won't work. mine kept freezing during games like after 3 mins. and it wouldnt read any more discs for that day. you need to change the blue ray reader and that costs about 175$. thats alot of money and its probably not worth it.
Apr 06, 2008 | Sony Playstation 3 (PS3) Console
Won't play PS3 games
u might want to go online and type clean discs the clean ur discs and they start working again orgo into game and they give u a new ps3
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Sony Playstation 3 (PS3) Console Logo
95 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
