Question about Panasonic DMR-E55 DVD Recorder
Charter cable tv just went digital so i now have a digital receiver (HDMI Dolby Digital Plus DCX3220e) I want to still be able to record tv shows with my Panasonic DMR-E55 DVD Recorder but don't know
How do I connect my DMR-E55 DVD Recorder
5 Suggested Answers
Palmbeach
  • 185 Answers
SOURCE: DMR-E55 DVD Recorder
Hi Liz
The majority of problems with this particular model are associated with the power board. The drive unit is unlikely to be faulty. Do not risk further damage by immediately trying lense cleaning as suggested by some. The lense will very rarely require cleaning.
The power board can be repaired if you have some technical ability. I have posted full instructions on Fixya on how to do this but you would need to be able to use a soldering iron. These are good units that can usually be restored, so it would be a pity to throw it out for such a fault,
Posted on Feb 03, 2008
  • 176 Answers
SOURCE: connect dvd recorder to cable box and hdtv
I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
On step 3 of the connections section substitute the follow for your situation.
You will need 1 component cable (Red/Blue/Green/Red/White cable)
3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
Other than this variation all shoud be the same.
CLICK HERE for complete tip.
Good Luck...
Posted on Jan 27, 2010
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
SOURCE: DVD recorder will not pick up digital channels from TV
Our DVD recorder DMR-EH57 is recording but not able to show its video
recording to the LCD what is the problem.
Posted on Jul 02, 2012
Can't access Dolby digital surround mode on my rca home theater system. Using hdmi cables but only getting Dolby prologic settings.
From where is the signal coming?. If it's a PlayStation, Xbox or bluray player settings may be needed in order for it to operate in the desired way.
Also the content has to support Dolby Digital like a tv show even if the receiver had DD the program also has to be in DD.
A lot of new players such as Fire Tv, Apple TV or Roku now send a Dolby Digital Plus signal which only newer-ish support. It's sort of a blanket signal that covers Dolby Digital but won't read as such. It will display as Dolby Digital Plus.
I can help with settings if you give details on the devices. Receiver type. Media type.
Mar 05, 2017 | RCA Audio Players & Recorders
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Yamaha Receiver sound cuts out with Dolby Digital.
Your problem is related to HDMI technology not the Receiver. HDMI in it's current version 1.3b has worked out 90% of the current problems being reported by HDMI users. it's a problem with HDCP digital copyright protection and the recording industry not wanting us "consumers" to duplicate or record their DVD's. Your receiver and every other receiver with version 1.1,-1.2, & 1.2a just don't cooperate with BluRay and even HD Cable or HD Sat receivers. If you just purchased this receiver recently, return it and get an 09' model or equivalent with 1.3a or 1.3b HDMI technology. If this unit is "un-returnable" then, what needs to happen is you need to run component video and digital audio to the receiver OR Run your HDMI directly to your TV and run a Digital Coaxial to your DVD audio input on the receiver. Depending on how many sources you are running to the TV via HDMI will be limited to the TV's capability (how many HDMI inputs)
Now, if your TV is 50" or smaller, the difference between running HDMI and Component is unmeasurable to the human eye. So, if you have to run component, don't sweat it! just use good cable, ie. Monster, Phoenix, Translucent etc. I do theese installs every day, and I still prefer Component or DVI if available over HDMI. They just haven't proved the reliability to me yet and we're three years in! Hope this helps
Jun 23, 2009 | Yamaha RX-V563 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
HK AVR35 Receiver - Dolby Digital not displaying or working
If the display is showing as optical/PCM, then the input signal is in 2 Ch Stereo.
Try to change the signal from the source i.e. the DVD player, On the remote, go to audio and press repatedly , the audio would change from audio1, audio 2 .... and so on, depending upon how may have been recorded on the DVD. If the DVD is recorded in Dolby Digital, it may show the audio as Dolby Digital 5.1 on you monitor. Once this setting has been done, your Receiver should automatically detect it and show as Optical/Dolby digital.
Please let me know if you you solve your problem.
Mar 12, 2009 | Harman Kardon AVR 35 Receiver
PCM 2.0
I had the same problem with my 321 system. The fix is in the cable box settings. You want to change the Digital Out on the cable box..my choices were HDMI....Dolby Digital..and None. Choose Dolby Digital and it will show up on your Bose 321 display. I also have my cable box connected to my bose system via optical digital cable...and a digital coaxel cable from my dvr to my bose. Change that output setting on my cable box took care of the PCM 2.0 problem for me.
Dec 19, 2007 | Audio Players & Recorders
Source always PCM, can't get Dolby-D
PCM is standard when using HDMI cables, you are passing an already decoded audio signal to the receiver and it outputs the sound and does nothing more. The reciever calls this PCM, your PS3, when pressing select should show that it is decoding the dolby digital HD. There is no quality difference in the two. PCM is the same because it is un compressed audio. So when using HDMI, no matter the signal that the movie or music is playing, wether it be dolby or DTS, you will see PCM when using HDMI.
Nov 24, 2007 | Onkyo TX-SR605 Receiver
Panasonic DMR-E55 DVD Recorder Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
