Gmc sierra 1500 This link I have attached you can get access to complete guides online
SOURCE: removal of power steering pump on 1998 GMC Sierra 1500
you need a power steering pump puller the rest is simple any trouble let me know
SOURCE: trying to install an aftermarket stereo 1994 GMC 1500
You have to unplug the old radio. The radio isn't the part in the dash. That is just the control to the radio. The radio is actually under the dash above the accelerator pedal. It should have the power wires, speaker wires and antenna wire going to it.
SOURCE: How to install passenger side glass on a 1997 gmc
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Remove the clips and screws securing the old window to the arm and slide it out through the top of the door (may need to be maneuvered out)
SOURCE: 1990 GMC Sierra 1500 pickup. Windshield wipers, Cruise Control
May want to look at replacing the wiper circuit board.It is located on the firewall adjacent to the wiper motor and has a some what square black cover with 3 torx screws and wireing harness pluged into the side.We had a truck that every time you washed it the wipers would stay on until it dryed out.You can try removing it and spaying it down with contact cleaner just watch the brease on the two contact tips.Well hope this helps.
SOURCE: 2000 GMC SIERRA OBD DOES NOT REGISTAR THAT IT'S
FUSE UNDER HOOD FOR CIGARETTE LIGHTER IS BLOWN
