Savin error codes
This message keep reoccurring
  • Ciaran Crocker
    Ciaran Crocker Mar 27, 2014
    Hi chip kidd, I want to help you with your problem, but I need more information from you. You're not specifying any error codes that I can work with. Can you please add details in the comment box?
3 Suggested Answers
SOURCE: service code 990 savin 2545 copier
If changing the cylinder, developer and blade the problem is not solved, proves to resetear software pressing by more than 10 seconds the point (.) and the numeral (#) both simultaneously, until it is extinguished and it returned to ignite the machine, this resetea software. If the problem persists, then the problem can be in the hard disk, replaces hard Disk.
Si cambiando el cilindro, revelador y cuchilla no se soluciona el problema, prueba resetear el software presionando por más de 10 segundos el punto (.) y el numeral (#) los dos a la vez, hasta que se apague y vuelva a encender la máquina, esto resetea el software. Si persiste el problema, entonces el problema puede estar en el disco duro, reemplace el Disco duro.
Posted on Aug 27, 2009
  • 132 Answers
SOURCE: How do l fix error code 108 on swf embroidery machine
Improper read.... Try reloading pattern
Posted on Jun 22, 2016
User codes.
that's due to having too many users..you'll need to delete some folks to make this work...maxing out the user codes will freeze the unit..
Apr 25, 2008 | Savin 9935DP Laser Printer
I have a Savin 8045e connected with USB and can't scan
its needs to be connected via network to scan and not usb i believe
Apr 12, 2010 | Savin 8035e Copier
Savin 8025 SC-546 error message
you have an over heat error. you need to test your thermistors, s and lamps for continuity.replace bad parts. then you need to go to service mode and reset the code
Jan 28, 2010 | Savin Office Equipment & Supplies
Savin Copier 2020, IP 192.168.2.100 functional error SC672
yes a 672 is an address book error. do you have scanner feature on this machine?. it may be bad. you may need a tech to come remove the option. turn the machine on and use it as a copier. then reinstall the option and see if the error returns. it could be a static build up or the option is bad.
Dec 26, 2009 | Savin Office Equipment & Supplies
Error code E-4
You only have part of the error code. You need to hold down the "." key in order to get the rest of the code. Since there is only 3 error codes that begin with 4, I'll post them here so when you find out what the problem is, you can attempt to solve it.
E405 - Transfer belt/drum charge roller position abnormal
E440 - Main motor lock
E442 - Drum charge thermistor abnormal
It's most likely not the third, as this one doesn't normally cause the machine to stop operating. The first two can be reset by turning off the main power switch for a few seconds, then turning it back on. This will clear the error, provided it's not a hard error (one that reoccurs during the machines warm-up cycle).
Just so you know, due to the age, parts for this machine are getting hard to get...
Dec 16, 2009 | Savin Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
Savin printer showing E 54.What does this mean?
If it's actually a Savin 2575, then you're missing a digit in the error message; However, any Savin machine that gas an error of '54x' relates to a fuser problem, and it can only be reset in service mode after the problem is fixed.
Jul 14, 2009 | Savin 2575 Black and White Copier
Df-3035 copier
Hello flyersgirl68,
I truly wish I could help you. But , you would not believe how helpful it would be if I knew what brand copier you have. Canon makes a 3035 copier but they have no error codes that start with f. Mita "MADE" a copier (1986) that had an "f" in their error codes that indicated the feeder had a problem. I guess we might want to narrow it down a tad. Is your machine a ...........canon,olivetti,mita,ricoh,savin,oce,kodak,xerox,minolta,konica,nashua,pitney bose,danka,savin,gestetner,monroe,ibm,imagistic,panasonic,toshiba,lanier,brother,riso,......etc....
Apr 18, 2008 | Office Equipment & Supplies
Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
