Question about Sony Playstation 3 (PS3) Console
Sony Playstation3 the console seems to be overheating after turn on causing the unit to freeze up the video, the fan is running but in low speed, the powersupply is very hot to the touch what would cause the unit to be running so hot? thanks in advance for help
  • 78 Answers
Re: Sony Playstation3
Seems to be the same issue as the Xbox 360 they have a cooling fan that attaches to the back of the system you can read about it here
Posted on Oct 31, 2007
0 characters
3 Points
My playstation3 freezes and when it restart my controlers wont work what can i do?
on the back of your controller there is a reset button have to use a pin to get in and reset it as far as the ps3 freezing its probley the fan going bad and causing the ps3 to overheat, does it just freeze up or shut down.
Jan 17, 2014 | Sony Playstation 3 (PS3) Console
My playstation3 wont show up on the tv seems to be really hot
The first thing you should do is try manually resetting the video settings on your PS3. To do this, first be sure your unit is off and the red light is visible. Hold your finger down on the power button and you will hear 3 beeps before the unit will turn off. Once this is done, turn the unit back on and you should have video.
If the unit is blinking a red light, this is known as the Yellow Light of Death for the PS3. This is caused when the unit overheats, causing the solder on the board to melt and bridge (connect). Once this happens it shorts out the board, causing the error you have now. Contact Sony and see if the unit is still under warranty.
If the unit is not under warranty, go to ore call toll free 1-888-389-3038. We are a console repair company based in Texas, and we can get your console up and running again. All of our repairs come with a 90 day warranty that covers the entire unit, not only our repairs. We also offer extended warranties up to 4 years at additional cost.
Jun 22, 2010 | Sony Playstation 3 (PS3) Console
Ps3 freezes after start up or after game starts
i believe the unit is overheating, thermal circuit overload or the device, memory is full, any of these will cause the desired effect. lockup. test by placing a cooling fan close to unit and have it blow the air past the unit and away from it,
Dec 21, 2009 | Sony PS3 40GB Best Sellers Bundle Console
What to do when my ps3 freezes during a game?
PSP freezes are usually caused do to overheating. This is a known issue ever since sony launched this cool console. The best way around this is get a USB powered coolant fan that will help cool the system and keep it from overheating even after sustained gaming for several hours. You can get one from the link below.
Oct 12, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is 15months old and the screen is freezing after 15mins the fan doesnt seem to be working so the console is getting hot
if you think the fan is not running it may not or on new models the fan is so quiet so put your hand on the back of the unit and see if you can feel air coming out of the unit if not then I have fan on sale or you can send your unit and we can tested and install a new fan or fix your freezing problem if the fan is ok
Jun 06, 2009 | Sony Playstation 3 (PS3) Console
Console freezing in main menu after a min green and red dots
do not perform fan test not good for unit. use vacume to clean out unit. if it was the motherboard it wouldnt turn on at all.
Jun 01, 2009 | Sony PlayStation® 3 (60 GB) Console
My playstation3 keeps freezing and wont let me play some of my g
It is freezing because your playstation is to close to the tv and its getting to is due to overheating you are having this problem ... so try moving it to another must take care to keep it properly vented.......
The system is prone to overheating, particularly if you happened to have bought older stock.
One way to deal with this is to stand it vertical, and put a small desk fan behind it.Turn on the fan when you turn on the game. I know it's an annoyance but it is a very simple and effective way to work around the problem.
DO NOT use an intercooler fan or any cooling device that gets power from the playstation. It just makes it worse.
when thermal compound fails it gets overheated so you need to look into this too ...replacing the thermal compound on the heat syncs and it should only cost about $5.00 to fix your playstation.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 no display no sound
if the ps3 shuts down on its own it is due to overheating. It is necessary to disassemble the unit and apply AS5 compound and shim the heatsinks to ensure proper contact between the heat sink and the processors. I can do this for $55 or you can send to SONY if under warranty. If not under warranty they will fix for 150+tax call 1800345SONY
Nov 13, 2008 | Sony Playstation 3 (PS3) Console
Playstation3 freezes up
this is similar to the red blinking lights on the seems your cell processor has overheated resulting in a cold solder joints or worse bridged solder involving the BGA array...I have had some success in fixing these albeit limited. SONY charges 150 plus state tax and sends you a refurbished unit. i can fix it for 55 shipped if interested
Jun 08, 2008 | Sony Playstation 3 (PS3) Console
Ps3 like freezing
If the disc/laser lens are dirty it will cause the games to freeze, or if the system doesn't have proper ventilation it will overheat.
May 13, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
