Question about GE Continuous Feed Garbage Disposal GFC520F
Gfc520f - new noise, sounds wrong
Nine-year old unit. No prior problems. Started making new loud sound, didn't sound normal or good. Still gets power and spins. Unplugged unit. No foreign objects detected. Turntable spins freely. Noticed that one of the two rivets in the turntable (that hold the two shredding blades) is loose. The other is tight and firm. Am wondering if the new noise is caused by the rivet shaking loose and, if so, is this something worth fixing or, given the unit's age, if it just makes sense to buy a new one. Thank you!
MicrowaveSvc
  • 9047 Answers
SOURCE: Model JVM1640CJ03
If the turntable tray is positioned and seated properly, it is probably a failing turntable motor. You can find usually helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Mar 09, 2007
  • 49 Answers
SOURCE: Loud Popping Sounds
If this is a heat pump system it is possible that your fan blade is hitting ice on your condenser coil.
Posted on Nov 18, 2007
peyton32034
  • 410 Answers
SOURCE: GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Posted on Dec 19, 2007
SOURCE: GE Spacemaker JVM1631BB005 making noise
Many thanks to e3enigma above! I removed the synch motor under the turntable; all other microwave functions work fine and the grinding noise is gone, hooray! A trip to the appliance parts store tomorrow for a replacement synchronous motor and all should be well. Thanks again!
Posted on Jan 08, 2008
chris0fer
  • 5 Answers
SOURCE: HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
Posted on Jun 19, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
I have a Maytag MAV6300AWQ top load washer that is making a LOUD noise during ALL cycles. We lifted it up in front and looked underneath; the belts look okay; the large one had some slack in it; maybe...
If the belts are old they will allow the motor too much outward room, so that the motor shaft can rub against the bottom of the machine. Also make sure the motor rollers are not cracked, which they have a tendency to do.
May 08, 2011 | Maytag Washing Machines
I have a Magic Chef refrigerator in my apartment that is approximately 11 years old. It has worked fine until apprx a year or so ago when it became louder and was emmiting more heat. We cleaned the coils...
this problem is creating by compressor bec u said that this unit is about 11 year s maybe the wear and tearing of mechanical parts thats cause of vibration and humming sounds, of ref. heat is only normal try to replace new compressor or replace new unit of ref.
Feb 05, 2011 | Refrigerators
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
When washer is started make loud grinding noise
Very likely the bearings in the motor have begun to fail. You can replace the motor, but for a 15 year old DW, sometimes it makes better sense to just buy a new one. Depends on the features the old DW has, vs new, vs motor replacement cost.
Reply back and we can you more.
Dec 13, 2009 | Dishwashers
New Canon MP610 scanner makes loud noises
I own this model too. It is very quiet. Sounds like a problem inside unit. I had a different problem with mine so I emailed them. They were very helpful & are replacing my unit. You may want to email them. Here's the email address I used. Good luck.
If this was helpful plz take the time to rate this. Thank you kindly.
Canon Support - MFP [mfp@cits.canon.com]
Feb 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Vibration noise on optima Projectro/DVD unit
Hi mstadisasta
This is a faulty colourwheel that will have to be replaced as a colourwheel cannot be repaired.
It is quite easy to replace and I would suggest you to do it yourself if this unit is no longer under warranty.
All you'll have to do is get your hands on the new colourwheel from your local or nearest retailer.
Thanks for using Fixya !
May 25, 2008 | Optoma H30 Multimedia Projector
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
GE Continuous Feed Garbage Disposal GFC520F Logo
46 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
