Question about Supersonic SC-75MID 7" Android Tablet
My tablet is loading non-stop.WHY?
It is loading on the second part on android
I have an Insignia Flex 10.1" tablet with Android model NS-14TOO4 and it boots up to the insignia screen and stops will not load, how do I reset my tablet?
Some tablets reboot by holding the start button for about 10 seconds and releasing. Wait another 10 and try turning on as normal. Maybe yours is one of them.
Sep 02, 2015 | Tablets & eReaders
Wont load, says android has stopped
Hi, You fail to state what won't loadload and from what source. I presume that the android device has not stopped because if it had that would explain why whatever you were trying to load wouldn't.
Jul 12, 2015 | Tablets & eReaders
I have a Chromo 7" tablet, IOS wont start up.
have you tried to press the reset button in back of your tablet.
Jun 26, 2014 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
How to reset android tablet
I had this android tablet http://touch-tablet.co.uk/product/7-android-42-a20-tablet/
And to reset it you had to the following: You hold the power button and -vol button together for about 5 seconds.
Then you let go of the power button and keep the -vol button still held until the android creature loads and gives you some options.
Choose factory/data reset using volume keys.
Good luck
Dec 17, 2013 | Tablets & eReaders
My pipo m3 battery run flat while in use and now I cant reboot it. it loads as far as the pipo slogan itself and then just stops there
Plug it in and fully charge the battery. After that, attempt to power it on while holding the power button in. Had to do this three times to fix my daughters tablet, and held power button for about 30 seconds each time.
Nov 04, 2013 | Umi PIPO M3 Dual Core Tablet PC 10.1 Inch...
Wont go to log in and internal keyboard stopped working
It seems the system keeps busy starting up, checking and loading drivers for internal hardware or it tries to connect to something, but keeps on waiting for confirmation that it's found.
While undergoing this process, the operating system doesn't get a chance to load the software/drivers for your keyboard.
If there's a reset-button to return to original firmware, try to go for this. If this is not possible, you might have the option to use an flash-drive including the Android-version for you tablet and booting, re-installing Android from it, back to your tablet.
Oct 18, 2013 | Generic A13-MID 1.2GHz 512MB 4GB 7"...
The andriod tablet does boot
It is simple just hold power button, and volume up for 15 seconds so that you can get a new window which as you to format the data or restore your android tablet option. Choose restore and restart your tablet will work fine use the following url if you still have any doubt https://www.youtube.com/watch?v=24Jvf96780U
Jul 30, 2013 | Android 7 inch Tablet
Android tablet problems
Try going to system settings and select 'About Tablet' then checking you are fully charged and in good wifi signal select 'system updates' Update to any new version it finds.
Make sure it is fully charged with the screen brightness down (so it will last for hours, just in case). The last thing you want is a power down during an update...
Jun 05, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
My craig tablet will not fully load up..I only get the android symbol nothing else
My criag tablet as soon I turn it on it gets stuck on the loading point what should I do?
PLEASE HELP ME:-) :-) :-) :-)
Dec 22, 2012 | Tablets & eReaders
Supersonic SC-75MID 7" Android Tablet Logo
13 people viewed this question
Top Supersonic Tablets & eReaders Experts
Paul Bade
ka4iup
ka4iup
Are you a Supersonic Tablet and eReader Expert? Answer questions, earn points and help others
