Hi
Put car on stands securely and remove wheel.
Release handbrake, Remove brake drum.
Four bolts secure the stub axle, they will be very tight so use a freeze spray penetrating oil...lots of it. Some of these cars use allen head bolts so make sure the allen socket is good quality and is fullyhome before you undo the bolts.
When refitting, check the correct torque setting for these bolts.
These are usually replaced because the bearings have failed nd scored the hard surfaces....so...do fit new..god quality bearings and regrease properly!
Refitting is a reverse...please do clean and adjust brake shoes before adjusting handbrake. And always check your brake cylinders too.
Good luck
Roger
SOURCE: remove the timing belt on a 1988 vw jetta gl
email me at [email protected] and i do have the diagram and instructions.
