Question about Kodak P811 Personal Photo Scanner Factgory Sealed
P811 will not feed
Scanner will not feed
2 Suggested Answers
hichbiri
  • 3462 Answers
SOURCE: My Kodak P811 scanner will not pull the paper thru.
I would check it there is a kodal service Hodak scanner service centre nearby to be honest...the last thing you want to do with a quality photo scanner is put it back together incorrectly. But I am cautious when it comes to electronic devices.
Posted on Jul 19, 2015
Jul 19, 2015 | Kodak P811 8x10 Personal Photo And...
Need help with a Kodak Personal scanner
Kodak is passing the buck. You would think that they could provide a calibration card for their own scanner.
Jan 02, 2014 | PANDIGITAL Office Equipment & Supplies
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
ERROR L1-00
Scanner feed trouble.
The scanner does not complete feeding in the specified time.
Mirror unit abnormality.
The scanner wire is disconnected.
The origin detection sensor abnormality.
Mirror motor harness abnormality.
Use SIM 1-1 to check the mirror reciprocatingoperations.
When the mirror does not feed.
Check for disconnection of the scanner wire.
Check the harness and the connector between the mirror motor and the MCU PWB.
Replace the mirror unit.Replace the MCU PWB.
When the mirror does feed.
Use SIM 1-2 to check the mirror home positionsensor.
From the service manual: http://www.scribd.com/doc/74632095/ARM206-M161-SM-GB
Oct 12, 2012 | Sharp AR-M206
Pictures will not go to my memory card on my pandigital kodak p811 personal photo scanner. I have tried a different card and it still does not work
pilipino ba 2 , try mo linisin nang dry cloth or dry paper ung area whre you plug in the memory card make sure its clean because it might be the area whre the memory card is plugged .is not working .Is there any error message .Make sure the card is properly plug in .
May 22, 2011 | Office Equipment & Supplies
I have Sharp AR 5316 L1 00 error in my copier pls give tips urgent
L1 00 Content Scanner feed trouble.
Detail The scanner does not complete feeding in the
specified time.
Cause Mirror unit abnormality.
Check
and
remedy
operations.
Jul 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
Need a document feeder for 4990 scanner
I don't believe it is possible to add a paper feed to this scanner. The only hopper fed scanner of which I'm aware is the Kodak s1220.
Jeff Underwood 1Scan.co.uk
Feb 13, 2009 | Epson Perfection 4990 Flatbed Scanner
Does anyone know the difference between a canon ****** roller and an exchanger roller on a canon dr-2080c scanner? I am looking to replace the rollers that are ageing and now "picking" up more than one...
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set.
Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Jan 25, 2009 | Canon DR 2080C Path-Through Scanner
2004 Volkswagen passat transmission code p811
as per vw, you need to check transmission oil level., not an easy thing to do. if transmission oil level ok (no dipstick on these by the way). it is a mecahnical fault.
Jan 16, 2009 | 2004 Volkswagen Passat
Incomplete feed
try correcting the page width and make sure one page goes through at a time also you can press the bottom of the paper and it will feed better
Mar 18, 2008 | Xerox DocuMate 252 Path-Through Scanner
Kodak P811 Personal Photo Scanner Factgory Sealed Logo
77 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
