Question about BenQ PE7700 Multimedia Projector
Benq pe700 suddenly dies. No lights burn anymore.
It started up normally an when i plugged the hdmi cable into my laptop i heard a loud "bang" and it died. Now it doesn't do anything, no light no nothing.
4 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: BenQ FP591 15" monitor decides to die
Strange that both should show the same symptoms don't you think? Have you changed anything computer wise? Graphics card or resolution? Screeching noise is a puzzle too. How are they powered - internally or via a separate power supply?
Posted on May 31, 2007
Mark_Webber
  • 472 Answers
SOURCE: BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Posted on Apr 09, 2008
budmrtn
  • 11361 Answers
SOURCE: "out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 19, 2010
I used to connect my tv with my laptop using an HDMI cable, and all of a sudden, it just does not work anymore. What can I do?
Hi Cyril Lott,
There is a possibility that the HDMI cable might have failed so try connecting another known good HDMI cable and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Apr 12, 2015 | Dell Computers & Internet
I bought BenQ MP670 Projector second hand for 100 euro.So my problem is that when iI connected my laptop with my projector via HDMI cable, I got no sound.It is not the cable,I use it to connect my laptop...
Depending on what type of laptop or projector you're using the HDMI me not carry the audio signal. you may want to see what your audio outputs are and try hooking them up in addition to the HDMI
Nov 05, 2013 | BenQ MP670 Projector
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
Aug 12, 2011 | Samsung LW32A33W 32 in. HD-Ready LCD...
Starter suddenly stopped working. Loud bang when
It's most likely a timing problem, you may try too adjust it yourself; Loosen set screw on distributor and get a timing light. there also a chance it jumped a timing gear when you heard the loud bang..
Jul 11, 2010 | 1994 Chevrolet Corvette
My 1993 dodge shadow es wont start.. if it does then it dies right away... i was driving my car when suddenly it started to **** and the engine wanted to die then it did and the check engine light came on...
In caburator, check fuel needle valve not ****, or chect to see if you have water is floating on main fuel bowl caburator jets .Clean in general.
Oct 12, 2009 | 1993 Dodge Shadow
Drive light flashing
What kind of loud noise was it, like a clanking a banging or a knocking????
Nov 21, 2008 | 1997 Honda Accord
BenQ PE7700 Multimedia Projector Logo
20 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
