Question about Toshiba Satellite L305-S5908 Notebook
Usb and monitor ports and screen do not seem to be getting power
I tried connecting the laptop to another monitor without success, the usb devices don't light up when I plug them in, but the little camera card does seem to light up. The screen does not make any attempt to start. I have a parts computer if there is some power wire or something??
    Top Expert:
  • Toshiba Master
  • 25,740 Answers
A cooked GPU will cause that. If it has overheated, there are companies that can replace it but may be time to budget for a replacement motherboard or laptop.
Posted on Mar 28, 2014
  • 238 Answers
SOURCE: My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Posted on Feb 14, 2008
SOURCE: toshiba satellite a135-2326 usb not recognized
mine is a135 s2386,bios version 1.4, same problem
Posted on Sep 06, 2008
  • 146 Answers
SOURCE: toshiba a135-s2356 usb ports stopped working.
Check your Device Manager
XP
my computer right click
go to properties
then go to device manager
then go to usb
Check to see if it has an x on it if it does try new softaware
by right clicking on the USB and Update
Posted on Aug 13, 2009
  • 18 Answers
SOURCE: I have a Toshiba Equium A300D-x13 laptop computer
NO just double check your power cord plugin into your convience outlet maybe it possible damage only that's it. thanks..
Posted on Aug 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Laptop Won't Turn On (Toshiba Satellite U205-S5057)
Try a new power adapter before you try the other expensive tests and repairs. The adapters are notorium about failing after being used continuously . If you can check the outgoing voltage at the tip where it fits into the DC jack on the laptop would be good. Match the output to the rated voltage needed to peoperly power the laptop.
Posted on Sep 07, 2009
Laptopscreen black
If the laptop has a vga port plug a desktop monitor into it. If you do not get output to the external screen then it might be a motherboard problem. If you get output then the problem is between the plug into the motherboard and the screen. Make sure you have nothing else plugged into the computer, ie. usb ports.
Mar 09, 2014 | Computers & Internet
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
My HP OfficeJet J6450 stopped working after getting a paper jam. It is connected with a USB cable. I have tried deleting the printer and reinstalling the software without success. The software...
When installing the printer click on local printer and uncheck the box below it. I think it says something like locate my device. then on next screen click create new port, you should see USB001 in there.
Jun 09, 2011 | HP OfficeJet 6310 All-in-One Printer...
When i put the USB cable and connect to the LAP, its not getting charged. How can i solve the problem? do i need to install any software?
Hi - when you say "LAP" I assume you mean laptop or notebook computer. Some computer USB ports do not have sufficient power to charge (or operate) devices like cellphones, GPS, large external hard drives, etc. You may be able to charge if you disconnect all other USB devices that aren't needed to run the computer. In order to get around the problem without having to do all that, either purchase an external charger for the GPS (which may be fairly expensive) or purchase a powered USB hub.
An external powered USB hub looks like a traditional USB hub, except for the fact that it has a power cord to connect to your home power outlets. The power cord will often look like AC adapter. The powered USB hub is ideal because they provide additional USB ports, are fairly inexpensive, they provide all the power for the USB devices that are connect to them (the computer's internal power supply is not used) and it can power or charge devices connected to them without needed the computer to be powered on. Simply plug the USB hub into a USB port, and AC power source - then connect the devices that need a large amount of power to the hub's USB ports instead of the computer's USB ports.
The parts included with powered USB hub (clockwise from left): USB hub, USB connecting cable and AC power adapter.
Many powered hubs will work without the power adapter - however they will supply power to the devices connected from the computer's internal power supply.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 08, 2011 | GPS
HP laserjet m1522nf- I can't install software on my desktop computer. I have had this printer for over a year. Yesterday, I plugged in USB cable from printer to my computer, as I have done many times in...
Do other devices work in the USB ports on the desktop? Do you use the same cable when you connect to the desktop and when you connect to the laptop or does the laptop connect to the printer via the network?
First try a different USB cable, unless other known working devices do not work. Try a different USB port. If you use a hub, try a direct connection.
I suspect you may be dealing with a port issue. Try going to the Device manager from the Control Panel and checking the status on the USB drivers. If you see a triangle with a yellow exclamation point or red x, try updating the drivers (right click on the driver). Then reboot the computer and check if this helps. Next try uninstalling the drivers and rebooting. Windows should reinstall the drivers.
Check your BIOS settings (depending on the computer press F1, F2, Esc, F10 repeatedly after turning on the computer - this may take a few tries) and make sure the ports are active. Also check in the screen saver advanced settings for a USB power saving setting.
You can try resetting the computer - unplug the accessories from the computer and remove the power cord from both the computer and the wall outlet. Press and hold the power button for 30 seconds. If you are willing to open your computer, try changing the CMOS battery (wait a minute after removing the old battery before inserting the new one). This battery is usually a lithium button battery (CR2032 is common).
I hope this helps.
Apr 12, 2011 | HP LaserJet M1522nf Multifunction Printer...
I have a Logitech cooling pad for my Dell 17" Studio laptop with 4 GB RAM and Vista Home Premium. It mysteriously stopped working. When I plug the cooling pad in other laptops, it works fine. I have...
Seems that your laptop's USB ports are not providing enough power to the cooling pad. This could be due to you connecting too many USB peripherals to your laptop. Test if you can get the cooling pad to work by disconnecting all other USB devices.
As a permanent fix, you can buy an active USB hub (one powered by external power source) & connect your cooling pad to it.
Dec 18, 2010 | Computers & Internet
I have a Dell Inspiron B130 computer and a Dell Photo AIO printer 966. Recently I could not get my computer to print on the printer. It had worked up to this point. I uninstalled the printer driver and...
First check the "Device Manager", for any USB Driver "errors".
There are 3 USB ports for your Laptop, check all the ports.
If you are using XP on your laptop, is your service packs up to date? For USB 2.0 port to function properly you got have to update a least Service Pack 2 for Win XP.
1. Have you check your USB port? Just plug in any USB devices eg. Flash drive, external HDD... and see whether the port detect the USB devices.
2. Is the USB cable for the Printer faulty? Try a new USB cable.
Hope it helps.
Nov 11, 2010 | Dell Computers & Internet
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Toshiba Satellite L305-S5908 Notebook Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
