Question about Nikon D3 Digital Camera
A black line (gasket?) has come across the LCD rear screen. What cuses this and how much to repair. Does not affect image.
This has just developed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
It is exactly that..... a dust gasket.
take it apart and remove it..... note where the gasket was around the screen and replace the gasket with double sided tape if you feel the need to prevent rattling or dust ingress (personaly i don't use or keep cameras in dusty places so i would'nt bother with the tape..... but if you keep it in a pocket or bag and use it on a safari, then you might want to do that.)
Posted on May 25, 2014
2 Suggested Answers
SOURCE: LCD screen dark and jagged lines
my nikon D80 did the same thing, had to replace the LCD. Their screens are very pedantic and screw up for no apparent reason, they also dont have as much shock resistance as the rest of the camera, as Ive learnt from expensive previous experiences....
Posted on Sep 16, 2008
White line across screen
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sony 46 KDL46EX523 LCD TV
A spot developed in center of screen next day black lines across screen from the original spot
it sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
May 02, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
Blue tint across screen and black shadow of sort
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Signal degradation across vertical section of
This appears to be a common complaint on LCD monitors. Some LCD screens have control issues.
An LCD screen is the panel and a bunch of Line control chips wrapped around the outer edge. A problem with one line top to bottom or left to right is almost ALWAYS the LCD panel itself.
A problem with a fixed band (The band is in the same place at any resolution) is often the LCD but might be the signal driver chip (A large plastic pack with about 100+ leads). A person with a VERY small soldering iron might be able to resolder it, but they MUST know what they are doing. (board must be heated, lead free solder, eye like an eagle...)
If the band moves around or changes width, it is the signal chip or the power supply to it from the power board.
It can be software if there is a firmware upgrade. This takes a shop.
Mar 19, 2010 | iiyama Computers & Internet
My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
Aug 07, 2009 | Sony Televison & Video
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Canon a80 lcd screen
The LCD screen's connection to the circuit board is not seated properly, or the LCD screen itself is defective. You are correct in that when you touch the screen you are affecting a bad connection. You should take the item back to the place that repaired it, or find another service center if they will not fix the problem for free. This is either a problem with their workmanship or with the LCD they installed.
Feb 22, 2007 | Canon PowerShot A80 Digital Camera
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Vertical lines jumping across screen
If the double image is in a differant color, then its your convergence IC's that need replacement. This is not a job for the unexperienced person. If you have no electronic repair experience, please seek out a pro to assist you in this repair. There are two IC's, about 3"X5" that are black in color and have STK with several numbers following them. Good Luck PS please dont forget to rate this thread.
Nov 02, 2006 | Mitsubishi VS-55705 55" Rear Projection...
Nikon D3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
