Sony bravia no digital channels
I have tried several different antennas with my sony bravia kdl- 46v 2500 and each time I do this can I only get two channels. The same thing happens when moving attenna in all different positions. Place attennas on other TVs in the house and get over 30 channels. Now I think there must be something wrong with the TV please help me.
    Problem Solver:
  • 12 Answers
If you've tried different antennas did you attempt to re-tune/re-scan for additional channels after switching? For digital channels to be detected they must be scanned for, so consult your manual on how to perform an automatic scan of the digital channels available in your area.
Posted on Mar 27, 2014
Testimonial: "Yes I rescanned after each position change and each attenna. Also mentioned hefore that the attennas work great on other tvs. The one that both attennas worked on is in an inner room that is cinder blocked. The tv that none of the attennas worked on is on a regular wall on main floor next to very large window."
  • 5 Answers
SOURCE: have a sony bravia kdl-40xbr2
yes you need now graghic card in your computer
Posted on Jan 22, 2009
  • 362 Answers
SOURCE: Sony Bravia does not see my digital channels
Hi buck lite,
Your cable company is telling the truth, you have digital cable. When auto scanned for digital channels the tv is lookig for OTR(over the air) signals. These are broadcast signals you will need an antenna to receive. Depending where you are and the type of antenna you use you probably could pick up some digital channels. Let me know if this helps and please rate this solution. Lone99star
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
To wayne: The balancer board is in fact available by itself. You can get it at many different parts depots here on the web. I just suffered from a similar problem, on the same tv and it solved my problem perfectly (Stupid 13 blink, blink code...)
The searchable part number is SSB400WA20. Its referred to as a voltage inverter (for the backlight of the lcd panel.)
Good luck!!!
Posted on Jul 08, 2009
  • 8457 Answers
SOURCE: LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Posted on Mar 20, 2010
Testimonial: " "
  • 31 Answers
SOURCE: My Sony KDL-46V2500 can't receive digital channel
signal booster, different tuners require different signal powers, by splitting the feed you've effectively halved the signal strength, a booster should bring it back,
Posted on Apr 19, 2010
Antenna channels
use digital antenna via radioshack
Jan 24, 2014 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Sony Bravia has lost all channels besides ABC and 7 Network, this happened while the TV was on, what is wrong?
unless you are on a antenna look in the menu to make sure set is on catv and not air or antenna.
Sep 03, 2012 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
Using an antenna on KDL-32S5100
No you do not. Your Sony already has a digital tuner. If you are not getting all the channels you think you should, you just need to keep progromming your TV with the antenna at different locations to maximise your signal.
Apr 17, 2012 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
My Sony KDL-52xbr4 was working fine until I did a re-scan of the digital channels. After the re-scan the TV finds no digital channels. All other TVs hooked to the same antenna work fine. The sony scans up...
Hi check to make sure the antenna is connected correctly. try tunning the channels manually and if they come up you can save them one at a time. Also try moving the antenna to a different location. make sure the TV is set to scan on the same input that you are connecting the antenna. If all that fails ou might have a defective tuner board.
You can get parts for this tv at www.interliquidparts.com
Nov 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
Sep 11, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My Sony KDL-46V2500 can't receive digital channel of our outdoor antenna, the same antenna line that feeds to another TV that works fine, can someone help?
Apr 19, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hi buck lite,
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
How to improve picture quality?
are you using an hd source ? hd cable box, satelitte receiver or antenna with the digital channels programmed in. regular tv channels will not look as good as the picture you saw in the store when you bought it. they all use only high definition signals.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Locking digital channels
UNFORTUNATELY THE ONLY WAY YOU WILL GET BOTH IS WITH A SECOND ANTENNA. IF THE SET DOES NOT SEE THE SIGNAL IT DOES NOT LOCK IT INTO MEMORY.
Dec 10, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony BRAVIA KDL46S2010 Sound and Pix not in sync - in HDTV channels only
This is a software issue with both the TV manufacture and the cable box provider. This will only be fixed when the cable company and TV manufacture sit down and work out their problem. Some cable company has taken the first step by updating cable boxes with different software.
Best regards
CircuitCity
Nov 24, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
159 people viewed this question
Top Televison & Video Experts
Electro Med Services...
