Question about Acer Computers & Internet
I place my windows 7 dvd into the drive but i cannot format my hdd but it just ask me to restore so how do you format it?
I cannot use the restore from my hard drive and my dvd disk 3 will not finish installing files to get it working. I know now I will need a fresh install of windows 7 64 bit and I have the files for the devices.
  • 1,162 Answers
Have you tried to right click on your drive an go to proprieties an do it from there? I did it on XP not sure it can be done on 7 but its worth a try.
Posted on Mar 27, 2014
Testimonial: "Yes I have tried it but I have a black screen and now it is in the Acer Erecovery Management and it will go through and after it gets all the way, I am back to where I started from. I had all three disk to recover this computer but the third disk is missing or someone picked it up. I do have another set and all three will install and when I get to the third one it starts and goes half way and restarts and back to start windows or the safe mode. I tried to order the disk from Acer but they say the S/D is not right and that is what is on the case. Thanks for your time in reading this and trying to help."
SOURCE: IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Posted on Sep 04, 2007
  • 3940 Answers
SOURCE: REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
Posted on May 19, 2008
  • 341 Answers
SOURCE: undetected com port 3
You may have to enable the other com ports. You go into the Control Panel and click on Add&Remove Hardware. When the first window shows up with everything that is already installed list, look at the top of the list. Highlite Add New Device. When ask, choose Select From A List. Then select COM Port and follow the wizard.
Posted on Nov 26, 2008
blueextc3221
  • 15935 Answers
SOURCE: windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Apr 10, 2009
SOURCE: why my acer e500 cannot install 64 bit window 7 it
you need to install Uli sata drivers in order for your motherboard to recognize the harddrive and cd drive.
download the drivers here: http://www.soft32.com/download_184082.html
and put them on a cd or memory card, when the system prompts you that you have no harddrive, you can load the drivers from a memory card or cd however if you use a cd you will face other issues. then you will be able to install windows 7 ;)
I did it on my acer e500 and it runs good.
I didn't install the 64 bits version though but the 32 bits.
for all the people saying that his pc is too old: if the pc can run under vista, it runs better under windows 7
Posted on Jan 31, 2010
Cant install Windows 7
Makes no sense. All operating systems during install have generic drivers designed to work the installing drive. If you are getting this message it has to be bogus and I suggest trying another dvd drive in its place.
Mar 29, 2014 | Computers & Internet
M Brand new DVR doesn't recognize its SATA hard disk? I have confirmed there is power on Hard disk. when it was not working. I format it by using windows 7 and reinstall it . what the reason?
is this the hard drive you recieved with the DVR? it is possible that the HDD is set up in the wrong format. windows sets up your HDD in a NTFS format which is compatible with most DVR's but i know there are some EverFocus units that read the HDD in a diffrent format. if this is the case you need too check in your owners manual in the HDD section, it should tell you what format it records onto, then place the HDD in your PC and reformat it to the right one.
Nov 03, 2013 | EverFocus EDVR16D1/500 16 Channel, 120...
I want to remove all my hardware and re install the orginal software that came with the computer
Okay, first save all documents you need etc. Then set the bootsequence in your bios as cd/dvd first and hd second.
Place dvd and startup; touch key when asked to startup from dvd.
When asked where to place windows first format c: drive. Then you start all anew.
The rest should be a snap.
Jan 08, 2013 | Acer Aspire M1610 Drivers Recovery Restore...
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
Using Windows 7 Get msg. If Disk is ungormatted you need to format it.
Windows 7 does this to many drives whether it needs formatting or not.
Right click on the cd/dvd select properties see what options are available you might select customize option restore to defaults then click apply.
Hope this helps.
Dec 08, 2012 | Computers & Internet
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Jul 11, 2011 | Computers & Internet
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
Lenovo y510 Dvd drive is not displaying
... and no drivers came with the drive either? Do you have the restore CD/DVD provided by Lenovo? I'm guessing this was a pre-installed OS and all files came on the HDD. When you installed Windows 7, you lost the path to the std Lenovo drivers... or wiped/formatted the HDD and lost everything? Can you pull the DVD drive out of the bay and see who makes it? Lenovo does NOT make DVD ;-) I'll bet it is a std Yeasu, Phillips or Samsung/Sony and with the model# and your OS info you will be able to get generic drivers for it
Good Luck
...As an example, my Top of Line HP has Sanyo drive ;-)
Jan 15, 2009 | Lenovo ThinkPad T61 Notebook
Computers & Internet Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
