Question about Carrier Heating & Cooling
Ciac air conditioner ff error code
AC unit goes off after ten minutes displaying ff code
  • Max power Sep 14, 2016
    The out side fan motor maybe failing, stopping the a/conditioning cycle.
    Master:
  • 363 Answers
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Dec 20, 2016
  • Carrier Master
  • 1,243 Answers
FF code means blown or missing damper fuse. Replace damper fuse (inside equipment cover plate) and try again. If damper fuse blows again, find and fix the problem causing the fuse to blow.
Posted on Mar 31, 2014
justaplumber
  • 98 Answers
SOURCE: Electrolux air conditioner
Tell me the model no. and I will find info or a new manual for you.
Without this info I cannot help you as there are many different coolers made by electrolux.
Posted on Dec 23, 2007
burzerko
  • 254 Answers
SOURCE: air-conditioning; error code: 425
Try Samsung.com
Posted on May 30, 2008
tatunka
  • 85 Answers
SOURCE: Hi, my Panasonic CS-E12HKR air
http://www.aircon.ru/pbc_download/files/f1147680661.pdf its about the memory norefregerant. look at page 47 for error codes
Posted on Nov 14, 2008
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
SOURCE: Air Conditioner Error code?
I have a portable air conditioner by Airlux and todat an error code is on the display reading E5. What does this mean and how can it be fixed? thx
Posted on Jul 08, 2010
Solution for f6 code in voltas split ac
Indoor unit fan motor is defective - good luck
Read more: Voltas saplit ac not working error c ode in display f6? - F6 error code in split voltas air conditioners :: Ask Me Fast at http://www.askmefast.com/Voltas_saplit_ac_not_working_error_c_ode_in_display_f6-qna8442437.html
Jun 05, 2016 | Heating & Cooling
WHAT IS ERROR CODE H5 FOR A FRIGIDAIRE HEAT/COOL WINDOW UNIT?
Thank you for your inquiry, Angela Babin!
From my understanding your Frigidaire air conditioner is displaying an error code "H5". Normally, the error code "H5" stands for heater thermistor error. I would recommend performing a reset on your air conditioner by unplugging it for ten minutes. If that does not help correct the error code it could be a possible problem with your thermistor or control board. I hope this is helpfully. -Matt
Nov 02, 2014 | Frigidaire Heating & Cooling
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
Error F8 on a Frigidaire AC model FASE24C6****
Good Afternoon Konrad,
I understand that you are receiving an F8 error code on your Frigidaire air conditioner, model# FASE24C6. I also see that it will work for hours before displaying F8 or sometimes only minutes before displaying the error code. The F8 tells me that there might be a key stuck. I suggest resetting your air conditioner, by unplugging it for 3-5 minutes. Plug your appliance back in and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire Heating & Cooling
Where is "flipper switch" on model PH3-12R-03?
Try first unplugging the unit for ten minutes, and emptying the water tank. If the error does not clear, then replace water tank flipper. see how that goes
Jun 05, 2014 | Heating & Cooling
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Ciac inverter error code "U8
two error codes i get "H6" and "U8" after u8 system will not run at all..carrier is no help and service people have no ideas
Sep 17, 2013 | Heating & Cooling
CIAC High Wall H3 Error. Will not cool.
my CIAC wall mount unit evaporater is freesing what can it be.
Aug 16, 2013 | Heating & Cooling
Ciac air conditioner error 6
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other AC Advice. Check us out online. WPB AC Repair
Jun 29, 2013 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
Dec 10, 2010 | Heating & Cooling
Heating & Cooling Logo
924 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
