1997 sony trinitron tv display/power malfunction?
Kv20vm30 sony trinitron- when plugged in, first makes a small chirp. will not turn on until waiting for 5 minutes or so for it to make a high pitched squealing sound. when turned on, the audio is good, but the display only shows a bright white line in the center of the screen. help?
  • 76 Answers
More expensive to fix than replace. Throw it out. If you're interested it's probably a bad capacitor.
Posted on Mar 27, 2014
Testimonial: "you're right, i checked and there were 2 that had busted. thanks!"
jomaru
  • 337 Answers
SOURCE: No picture only a high pitch sound
Yes,it can be repaired,sometimes for no reason components fail and they need to be replaced,if you are familiar with tv service you can check the horizontal output transistor,it might have gone bad(shorted out)and is all is going to take to get the set back running,sometimes the output trasformer damages the transistor and both have to be replaced,first just change the transistor and if it blows up again then replace the transformer,if you are not too familiar with servicing a tv be safe and call for assistance from a servicer,if you take the set to them it should be expensive.Let Us know how it goes or if you need more information.
Posted on Nov 08, 2006
  • 192 Answers
SOURCE: high pitch sound for Sony FD Trinitron WEGA KV-27HS420 27" TV
The high pitch squeal you hear is usually caused by a coil vibrating, normally in the horizontal circuit. I've also seen the ferrite bead on the horizontal output transistor do this, but, it is rare. I normally will repair this by finding the coil and "tightening" it. To tighten a coil, technicians use different chemicals, such as, a hot glue gun, rubber silicone or even finger nail polish. I will find the coil that screams by starting with the usual suspects and using a wooden dowel, barely touch the coil and if the pitch of the noise changes, then, thats the coil that needs repaired. If you do not know your way around the inside of a television, I never recommend you do so, since, this procedure must be done with the set turned on and you poke your hands around the inside of the set by the high voltage circuit. Hope this helps your decision.
Posted on Mar 04, 2007
CompuGuy44
  • 432 Answers
SOURCE: Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Posted on Jul 04, 2007
SOURCE: TV screen wont turn on but just a loud noise coming from the tv
i have a panasonic ct32sc13g flat screen tv 2003 model wont come on no lights will come on
Posted on Dec 20, 2007
salt56
  • 373 Answers
SOURCE: TV does not turn on. When plugged into an outlet makes a high pitch noise.
Your problem is a shorted horizontal output transistor C5148 located behind the highvoltage transformer on a heat sink with a clip over it and you can't see the number unless you remove the clip Has to be unsolded and solder in new. Also the highvoltage transformer must be replaced This is the big part with the large red wire coming out and going to the top of the picture tube. Must be unsoldered and replaced with original RCA .....do not get a replacement It has several connections plus three wires to connect to it and I recommend using desoldering brad can get at Radio Shack 5 foot roll. Well as you can see it gets pretty involved. You can't get the parts from most distributors unless you have a business. If he tackles it and has a distributor the parts would run about $50 to $60 and a repairman average should be less than $200 and more than $150 hope this helps. Contact me for any questions you may have. I am more than willing to help.
Posted on Dec 30, 2007
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
We have a Sony Trinitron Color TV that seem to be in a sleep mode and we can't turn it on. Would you know what the problem is?
Hello
Press the "Sleep" button on your Sony's remote control hanset until the TV displays the time in minutes [ 15,30,45,60 or 90] that you want the the TV to remain "on" before shutting "Off" automatically. Cancel by pressing until "Sleep Off" appears. The logo also will go out from the screen.
You just do this after unpluging the TV from AC wall socker for about 10 minutes or so, and then plug it.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How can i turn on the av channel on a sony trinitron KV-25F1U
Hi, look for a symbol either on the front of the TV or remote that shows a Circle with an arrow pointing into it from the left
Mar 21, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a sony trinitron kv36hs500 tv which power problems
try making resolders on power supply ckts, try also adjust screen voltage,, check crt socket,,if all of this dont solve it, try to rejuvinate the crt.
Feb 27, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV 27FS16 TV does not power on
The chirping is the power supply trying to start. This is not a repair that I would recommend a novice attempt. PLease have this unti serviced. Expect a parts cost in the $20-$40 range for power supply caps.
Dan
Aug 31, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I press the power button and hear the click but no picture appear
Unplug the TV Remove the cover wait until the TV cools then plug in, turn on and, it should come on... if it does; purchase a computer fan to cool the chassis of the TV wire it into the 12 volt side of the power supply and, install the cover
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32HS500 32" just stays on standby & blinks 7 times give no indication there were any probems.- wont turn on when you push the power button it acts like it is going to come on...
we have the same porblem. We just unplug ours and wait a couple of weeks while watching another tv plug and un plug it will eventually come on then we dont turn it off again it only goes off if the power goes off.
Jun 07, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SONY FD Trinitron Malfunction
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
May 13, 2017 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
Top Televison & Video Experts
