Question about JVC AV-32D305 32" TV
All of a sudden I cant change channels on my Pioneer Elite 150FD TV. I can just switch inputs and volume nothing else will work. Please help?
Most functions on my control stopped working
  • 1,162 Answers
If you have good batteries, remove the back an under the rubber numbers if you feel a wet substance, wipe it off an reassemble. It should work, the silicone rubber has a tendency to excrete this stuff. It fixed mine
Posted on Mar 27, 2014
MikeNJ1964
  • 398 Answers
SOURCE: the input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Posted on Jul 12, 2007
SOURCE: need factory service mode
i think you need to reset the eeprom,to open the service menu simultaneously press the DISPLAY key and VIDEO STATUS or P-MODE key of the remote control unit.
Posted on May 13, 2008
jerryg50
  • 1667 Answers
SOURCE: TV powers on and then cannot change channel or change volume???
The fault may be the control panel, or it may be in the uPC itself.
Most of the time, it is some of the switches on the control panel.
The most common cause of this type of failure is that many times when people clean the TV set, they spray cleaner directly on the screen or the set. The liquid runs down in to the set and causes damage. Sometimes the damage can be very expensive!
If the fault is just the control panel board, this can be easily replaced. You can order one from the manufacture's parts department or from one of their parts distributors.
You will need the service manual, a scope, and a DVM to troubleshoot the problem if it is more involved than just changing the panel. The only way to know is to try the panel unless you have a way to test it.
Jerry G.
Posted on Jun 30, 2008
Benimur
  • 6966 Answers
SOURCE: JVC AV-31BMS clock stopped
Based on your description, two (2) possibilities:
1. The JVC has a feature called TV Guide+. If yes it has one and it is engaged/enabled, then the TV will download TV program information and the current time, hence the clock cannot be adjusted manually. Pls try to disable this feature;
2. The logic circuitry controlling your OSD (on screen display/menu) would need looking over. Often this would just require basic cleaning of the circuit board and the components with special focus on the processor IC. After dust removal, a spray of electronic contact cleaner would help. There are occasions that a limiting resistor or a filter capacitor in the +5VDC rail would require check/replacement.
In some instances, it could be simple a case of weak batteries on the remote.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 10, 2008
  • 280 Answers
SOURCE: black screen on EVERY input/channel
Turn off the closed capition
Posted on Jun 19, 2009
I have a Panasonic TH-42PX50u that suddenly is stuck on one channel and no volume control either. Same whether using remote or on TV. Only turns on and off no other control.
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Look for jammed buttons on remote and/or on control panel. Try removing the batteries from remote and operating from the control panel of TV. If these are ok, Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 06, 2012 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Good day, I need your asst. I can't seem to remove the 2ch playback from my VSX-49TX Elite Pioneer reciever, I tried reseting it and nothing happen...can you help me.
If you have no sound, you can try the multi channel inputs on the back after switching to the multi chan input. If you have sound that way, you have a DSP problem. I can repair this issue to the component level, as many customers have found, the boards are very expensive, and no longer available. If you're interested in repairing your receiver, please visit my website at audioserviceclinic.com. There you will find the seminar I wrote for Pioneer, when I worked there as a Field Service Engineer, specializing in audio. You can contact me directly from my website. Thanks you.
Jul 14, 2011 | Pioneer VSX-49TXi Receiver
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
I have a Pioneer Elite Plasma TV style 435PU. I have Directv. I can't seem to get the television picture to come on because I accidentally hit a switch on the Directv remote control called "input" and I...
What you have done is change the input source. It will toggle through various modes like component, HDMI1, HDMI2, S-video etc., You should take a look behind the tv and see which input you have connected it into(usually HDMI 1 or HDMI2) then keep pressing the input button till it toggles back to that particular input.
Sai.
Mar 28, 2010 | Pioneer PDP-5060HD 50 in. Plasma...
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Can't change channels
I had exactly the same problem. I finally found the power button on the underside of the TV. It is well hidden and to find it, you need to run your fingers underneath the panel. Turn it off for a minute or so and turn it back on and then turn on the switch on the panel on the upper right side where the channel and volume buttons are. It works.
Aug 13, 2008 | Hitachi 42HDT52 42 in. Plasma HDTV
Sharp LC-42D43U troubleshooting with the maximum volume sound
Found this on another site and it worked, had to switch back and forth a few times but it worked........
I have a Sharp LC-46D43U LCD TV. I think this is a entry level for large lcd tv's. With the volume all the way up at 60, my wife and I could barley hear the tv. I was playing around in the menu and some how have the volume at almost twice the volume. What I did was:
Go into the menu
Go to option
Go to output select
and change from fixed to variable and back to fixed. You may have to do this a few times.
Sometimes the volume goes loud after 1 try and sometimes it may take 10 or 20 tries.
But if I change any settings, even the channel sometimes the sound goes back down to where it was.
Has anyone done this, did it work for you. I don't know very much about electronics and I have now ideal why this happens.
I wonder if this is just something with my tv.
Mar 03, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
Universal remote(s) won't work
Use the buttons on front of your (tv) channel up & down allows you to scoll thur menu vol- vol+ allows you to adjust settings.Need anymore help let me know. ThankYou for using FixYa. Have a Nice Day.
Aug 26, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
JVC AV-32D305 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
