Question about Panasonic TC-P46S1 TV
Remove back tc-p4621
Remove back dust
    Top Expert:
  • Panasonic Master
  • 74,377 Answers
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 28, 2014
What is the speed range for moving our Miele Solaris S 514 horizontally over the carpet for optimum weekly dust removal?
When the dust is gone the speed is correct . You should use a back and forth movement so the rug fibers contact the machine efficiently. There is no perfect speed since the amount of dust in a carpet is not uniform. Hi traffic areas will require more time spent removing dirt than an area close to the wall here there is no foot traffic.
Aug 14, 2016 | Miele S514 Solaris Electro Plus Vacuum
Dell inspiron one 2205 touchscreen overheating
Had a similar problem a non-touchscreen 2205 model. The cooling radiator was clogged with dust. You can unplug the power cable, remove the back cover and clean the dust out. I removed the cooling fan and used a toothbrush and vacuum to gently remove the dust matt from blocking the radiator. Use q-tips to gently clean the fan blades as well. Reattach the fan and the computer no longer overheated. By the way, Dell designed the 2205 with not enough ventilation. After cleaning. the CPU idle temperature ran at 39C with the back cover attached and only 29C with the back cover removed. The air flow intake for the cooling fan is taking in warm air due to the Hard drive heat being captured by the back cover.
Dec 30, 2013 | Dell Computers & Internet
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 | Vacuums
Showing error code 0046
Fusing motor cooling fan is in op due to dust build up, motor gone bad, or the main control board has gone, to reset open close front door, if it still come back (code) Then remove the back cover after unplugging and clean all filters and fans if one is dirty they all might need dust removal. remove each fan clean with can air make sure they turn properly.
May 26, 2012 | Minolta EP4000/5000 CS/PRO Copier
Casing getting hot, fan going mad then slowing down
Have you ever removed the side panel and cleaned out the dust from inside the computer case?
If your fans or air inlets get clogged up with dust then your machine will run very hot and could eventually shut down or cause permanent damage.
Unplug all the cables from the back of your pc, and remove the 2 screws from the back panel that secure the side panel. Then just pull back on the side panel and it will pop off.
Clean out all the dust from inside the case. You can use a vacuum hose but don't bang into anything with it. Also use a small clean paint brush to lightly brush the dust off of the fan blades and the CPU heatsink and around the power supply air vents. You can also use a can of compressed air if you have it to dislodge the dust and then **** it up with the vacuum.
Good luck and please comment back and RATE if this was helpful.
Feb 05, 2011 | HP Pavilion Slimline s3500f Desktop...
Red light green light on off all time tv will not turn on
ok if you have just replaced the bulb, first try taking out the bulb unit and putting it back in, if you have already tried this, then disconnect everything from the TV unplug it find a nice sturdy place where you can place the tv, at the back of the tv remove the lower back panel ONLY, the screws you need to remove will have an arrow pointing to them, once removed clean all built up dust, remove cooling fan and clean from dust , check it spins ok, remove silver plate in the middle and remove any built up dust, just to the right of the fan there is a sensor unsrew and remove check it is free from dust, on the left of the fan is a micro switch unplug but do not pull on wires to the far right you will see a retainer bar upright (silver) remove this, gentley pull all the circuit board assembly back it will not come out far, on the back circuit board unplug the top two plugs top left but DO NOT pull on wires pull the circuitry board forward just a fraction more, and behind it is yet another multi plug, pull out the one to the left and plug back in but clear any dust in mean time, gently put everything back and plug all that you have unpluged back in gently, put all bars and covers back on, and re-install equip to tv........ this is what i did to mine when i had this probem today after bulb replacement and it now works fine
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Dust inside lense
Removing internal dust normally requires a full internal cleaning, lubrication and adjustment (CLA). Internal dust, if it is not a lot, will not affect picture quality at all. On many camera lenses you can stick the small tube on a can of compressed air into the back of the lens and a few moderate blasts may remove some of the internal dust. Yet this is not recommended since it is quite possible to accidentally dislodge focus cam or zoom cam grease and blow that grease onto a lens element or (worse) onto the aperture blades. So, the point is that mild to moderate amounts of internal dust won't affect your photos.
Mar 17, 2009 | Cameras
Lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Dec 09, 2008 | Lasko Ceramic Heater
Panasonic TC-P46S1 TV Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
