Question about Epson Stylus C88 InkJet Photo Printer
Replacement of ink
My printer epson stylus c90 need for replacement of ink yellow and magenta color because its is low already but i cannot remove the cartridge from the printer.I need to know how to remove the cartridge from the printer to replace for the color.
thanks
ivy
    Problem Solver:
  • 7 Answers
Hi,just go to the printers properties select maintainance select status monitor from there the procedure is self explanatory,try that.
Posted on Jul 01, 2009
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
Jul 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Can you tell me how to change ink on an epson stylus cx400
The Epson Stylus CX6400 is an all-in-one printer that also features a scannermag-glass_10x10.gif for scanning and copying. The Epson CX6400 prints with ink via four separate ink cartridges in black (high or standard capacity), cyan, magenta and yellow. The cartridges sit in slots in a cartridge holder underneath the scanner. As cartridges run low, or cartridge print quality problems arise, ink cartridge replacement become necessary. As each cartridge snaps effortlessly into the cartridge holder, changing cartridges doesn't require much effort beyond unsnapping the old cartridge from the holder and replacing it with a new one. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Instructions
  1. Step 1 Turn on the CX6400.
  2. Step 2 Check the ink levels for each cartridge. Press the "Setup" button to enter the setup mode. Press the topmost button on the left side of the LCD repeatedly until you reach the Ink Levels screen and then press the "Color" button to see the ink level percentages (for example, 0 percent or 50 percent) scroll across the screen for each cartridge (C for cyan, M for magenta, Y for yellow and K for black). Press the "OK" button to exit.
  3. Step 3 Select the empty cartridge or low cartridge option on your printer. If you're dealing with one or more empty cartridges, press the "Color" button. If you've decided to replace low ink cartridges, press the "Setup" button, press the topmost button on the left side of the LCD repeatedly until you reach the Replace Ink screen and then press the "Color" button.
  4. Step 4 Reach into the slots on both sides of the printer under the scanner unit. Lift the scanner unit up carefully to reveal the cartridge holder on the right side of the printer. Lean the scanner back to rest on its hinges.
  5. Step 5 Grip the unhinged end of the cartridge cover near the back of the printer and then pull the cartridge toward you. If this is done correctly, the cover should flip back and hang slightly out from the printer on a hinge.
  6. Step 6 Press your fingertip against the grooved tab on the cartridge that you're changing to unlock the cartridge from the holder. Once it is unlocked, pull the cartridge straight up and out of the printer and set it aside for disposal.
  7. Step 7 Shake the new replacement cartridge in its sealed packaging four to five times using a rapid side-to-side motion and then remove it from the packaging without touching the green circuit boardmag-glass_10x10.gif.
  8. Step 8 Insert the replacement cartridge in the holder and push down on it until you hear the grooved tab click, locking the cartridge in place. Remove and replace any other cartridges as needed.
  9. Step 9 Flip the cartridge cover over the cartridge holder and push down on it to lock it in place. Grasp the sides of the scanner unit and lower it gently into its previous position. Wait for the "Charging" message to disappear from the LCD and then begin printing.
Read more: How To Change Ink Cartridges for an Epson CX6400 | eHow.com http://www.ehow.com/how_6656725_change-ink-cartridges-epson-cx6400.html#ixzz0tZtUa2CB
Jul 04, 2010 | Epson Stylus CX6400 All-In-One InkJet...
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How do i eject the ink carrier?
hi there,
  1. Look at the Epson printer's LCD screen to see the ink levels for each cartridge. If your cartridge is completely empty, simply press the "Color" button. If your cartridge has a low ink level, press "Setup". Hold down the button on the upper left side of your LCD screen until the words "Replace Ink" appears, then press the "Color" button.
  2. Wait until you see the words "Open the scanner" on the LCD screen. Then lift open the printer top by pulling up on the side grips next to the scanner unit. Make sure that the scanner lid remains closed. The ink cartridge holder should move to the far right of the printer.
  3. After the cartridges have completely stopped moving, pull the cover of the ink cartridge holder up and toward you. Press in the tab of the cartridge you need to replace. Lift the cartridge straight up to pull it out of the holder.
  4. Unwrap the replacement cartridge and insert it securely into the holder. Press straight down until the cartridge snaps into place.
  5. Close the cartridge holder cover and make sure it clicks into place. Close the scanner unit and wait while the printer charges the new replacement cartridge. Wait until the word "Charging" disappears from the LCD screen before using your printer.
Do not turn off your Epson printer while the "Charging" message is still on the LCD screen because this may cause your inks to not fully charge. Turn off your printer only if there has been no response for over five minutes.
Clean up any ink spills with soap and warm water.
Replacement ink cartridge: Black (T048120); Cyan (T048220); Magenta (T048320); Yellow (T048420); Light Cyan (T048520); or Light Magenta (T048620)
Hope this initial info/idea helps.
Let me know for further instructions.
Thanks
Apr 29, 2009 | Epson Stylus RX500 All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
Epson c90
did you remove protective strip from cartridge
Jul 24, 2008 | Computers & Internet
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus C88 InkJet Photo Printer Logo
150 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
