Question about ION Audio SLIDES 2 PC Slide and Film Scanner
Can I use different software for an Ion Slides 2 PC scanner?
I have an older mac using tiger OSX.5
3 Suggested Answers
  • 32 Answers
SOURCE: Problem with SLIDES2PC
I think there is a buffer that has to be cleared after so many pictues ie processed.
Posted on Dec 14, 2011
  • 4 Answers
SOURCE: Where can I obtain software for my ION Audio ION
Download direct from ION Audio:
https://www.ionaudio.com/support/downloads/slides-2-pc
Posted on Mar 05, 2015
HP Photosmart C6280 Scanner not found with Mac Tiger
I'm using a software called VueScan, which has drivers for almost all scanners and works well. Maybe you should test it?
Jan 27, 2014 | Apple Mac OS X 10.4 Tiger for Mac
I have lost my driver software to install umax astra 2200.so how can i install the scanner on my mac os x 10.4.11
try using mac os 8.6-9.1 driver it is mac osx but older it might work
here is the umax link to softwarfe download
http://www.umax.com/download/index.jsp
select model 2200 and then mac os 8.6-9.1
May 20, 2011 | Umax Astra 2200 Flatbed Scanner
My dad is trying to convert slides to digital format using a Rollei DF-S 110 SE scanner. His Mac does not recognize the scanner and there does not appear to be a photoimpression 6 version for Mac. Any...
There's nothing you can do to make that scanner work for a Mac because it was made (and its software) exclusively for Windows.
You could try:
-use the scanner and its software on a Windows computer -go to a computer shop and have the slides scanned and saved on your flash drive
Mar 20, 2011 | Arcsoft PhotoImpression® 6 Full Version...
HP Scanjet 4470c compatible with Mac OS X 10.6.1
You will not find drivers for this old scanner. Sorry but this scanner is not compatible with Tiger, Leopard, or Snow Leopard, and HP offers no drivers other than for OSx 8.0 & 9.0 which are 10 years old. Time to purchase a new scanner.
Nov 10, 2009 | HP Scanjet 4470c Flatbed Scanner
Iogear gpu 202 cardbus not working with mac powerbook osx 10.4.11
Try the TechGear USB 2.0 cardbus. There are some available on eBay for $10.00. Item number is 250394104416. I bought two for older Titanium 15" PowerBooks, one on 10.4.11; one on 10.3.9. The cards works perfectly with no software drivers. I just inserted them into the PC slots and they work fine. In one case, one computer had a bad factory USB 1.1 slot, so the card does well for extending the comuter's life. The card included a CD with drivers for older versions of Windows and Mac 10.1 and Mac 10.2. I would NOT install drivers for newer systems.
Feb 27, 2009 | IOGear Cardbus Card GPU202 Serial Adapter
Require driver for Ion Slides 2 PC ... using Vista 64 bit.
MY ION SLIDES 2 PC WORKED WELL WHEN I HAD VISTA BUT SINCE CHANGING TO WINDOWS 7 IT WILL NOT WORK WHEN CLICK ON AQUIRE I GET THE MESSAGE CANNOT FIND THE SCANNER. PLEASE CONNECT 35MM FILM SCANNER. I HAVE UNINSTALLED THE PROGRAMME AND REINSTALLED IT BUT SSTILL GET THE SAME.
Feb 22, 2009 | Office Equipment & Supplies
Epson scanner 1250 software won't install on Macs w/ OSX10.5.6
See that must be an internal issue of your system either your system is corrupt or the driver is not properly installed.You need to install it properly and for more guidance on this issue just get in touch with technical support team of Epson and get connected by dialing 1-800-243-0019 and get your issue resolved within a short period of time
Aug 31, 2017 | Epson Perfection 1250U Flatbed Scanner
Ibook has gone nuts
What version of OS X are you running Jaguar Panther or Tiger? How are you trying to connect to the internet? Through a router or directly connected to the DSL/Cable modem? There are some things that you need to look at to get the information you need in the System Preferences Network tab.
First look to see if it says you are connected via Ethernet and what colour the "light" is (green yellow or red). If it is green you are connected and have an IP address, yellow connected but there is an issue with the IP address and or connection and red means that the ethernet does not show any connection to the network.
Depending on what that shows, look at the interface tab (may have to select advanced) and see that the ETH0 is present and selected and that it is first on the list.
You then go to the TCPIP tab and check that it is set for DHCP or automatic configuration.. If it is then try to renew the DHCP lease. If it is set for anything other than that, change it apply and try again.
I had a G3 iBook that was probably about the same age and specs, and I noticed it really only started working well after I put Tiger 10.4 on it. 10.2 was not great and of course with 9.x it would not run new stuff.
Feel free to ask for more help if you need it. I have A LOT of experience with the machine you have running different versions of OS X.
Dec 11, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
ION Audio SLIDES 2 PC Slide and Film Scanner Logo
Top ION Audio Video Cameras Experts
Are you an ION Audio Video Camera Expert? Answer questions, earn points and help others
