Question about Hunter Ceiling Fan Remote Receiver 85112-01
Westinghouse remote has had a surge, how do i get it to work again
Light and fan work fine. the remote control lights up(replaced the battery). the light and fan will not respond to the remote control since we had the power surge. can someone please help!! I want to get the remote control to work again.
    Genius:
  • Hunter Master
  • 1,617 Answers
You need a new remote receiver.
Posted on Mar 30, 2014
ceiling-fans
  • 20 Answers
SOURCE: Ceiling fan remote not working
It is certainly possible that the remote went bad -- after all, it is an electronic device, and is was "made in China". With that said, there are other possibilities:
* The receiver, which is what receives the signals sent by the remote control, could have died. In most remote-controlled fans, the receiver is located in the ceiling canopy (the decorative part up by the ceiling, which hides the wires). In other fans, it's located in the switch housing (the part of the fan to which the light kit attaches). Solution: try everything else on this list; if nothing works, replace the receiver. Universal replacements for most models are available at Home Depot and Lowes.
* A wire on that receiver could have come loose. Solution: check all wires for secureness.
* A wire in your wall or ceiling -- the wire which provides power to the fan -- could have come loose or been chewed through by a rodent. Solution: use a circuit tester to check whether there's power at the connections at the top of the fan, in the ceiling, where the fan connects to the building's wiring.
* A circuit breaker could have tripped or a fuse could have blown. Solution: check your circuit breaker or fuse panel.
* The DIP switches inside the remote control -- which set the frequency on which the control transmits -- could have been knocked out of position accidentally or by a child playing with it. Solution: check the code on the DIP switches on the receiver in the fan -- then, make sure the remote control has its DIP switches set the exact same way.
If none of the above work, then yes -- the problem is with the receiver or the transmitter (remote). The two are typically sold as a pair, and universal replacements are available at Home Depot and Lowe's.
Hope that helps! Feel free to ask for clarification if you need it!
Posted on Jun 17, 2008
  • 10865 Answers
SOURCE: need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
Posted on May 31, 2009
SOURCE: hunter fan remote 85095-02, red signal light glowing continualy
It's continually transmitting. My guess is there is a button stuck causing the unit to run down batteries. If no button stuck, you'll probably have to replace the remote -- it's a fulty transistor.
Charlie
Posted on Aug 25, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
Where to order remote control for my ceiling fan no.uc7130t
from the service dealer / authorized service agent for your brand of fan
Oct 25, 2015 | Westinghouse Televison & Video
How to reset remote and light/fan on hunter model 25739
You can go on-line @ www.hunterfans.com or call 1-800-715-0393. I think you might need a new receiver.
Jul 10, 2015 | Hunter 52" Ceiling Fan With Light And...
I have broken the remote for my ceiling light/fan. Westinghouse Uc7130t. Where would I get a replacement?
Hello Allan,
There is nothing universal about ceiling fans except some of the transmitter/receiver parts. Questions that would be helpful would be: How many "dipswitches" does your system use (the little micro switches usually found in the battery compartment)? Does the remote have an LCD display on the front or is it simple buttons with a little indicator light? If you have a simple remote with 4-dipswitches this remote should work: http://www.fanmanlighting.com/shop/pc/viewPrd.asp?idcategory=74&idproduct=884 It may look different from your remote and have a different brand name but it should talk to your fan if you set the remote to the same frequency as the receiver in your fan. If you have any questions you can reach me at 952-898-2754.
Kind Regards,
- Jack Jr
Feb 10, 2014 | Westinghouse Televison & Video
All 5 ceiling fan remote sensors not working
Check that the remote is working. Do this by using a digital camera and point the sender at the lens . If it is working you will see a blue/red dot on the viewer screen. It will move when you move the remote. You cannot see the beam but the digital camera can and shows it up on the view finder.
Mar 24, 2013 | Hunter Ceiling Fan Light Remote Control
I have a Westinghouse 77870 remote control with a light problem
read your intruc. manual and proceed according. download from www.fitness.manualsonline.com or www. retrevo.com
However you retight the spring contacts with pliers for better contacts batteries. 2) Open the re.control and clean the keypads for dirty, oxide with special spray contacts. 3) If the problem persist go to the repair shop TV for fix it.
God bless you
Jul 06, 2012 | Westinghouse 77870 Remote Control
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote will turn on the light, but not the fan.
I have a white Westinghouse tv and can not programs the code in a Rca universal remote control
could you give me the code for the tv. Thank you
Nardin
Jul 02, 2009 | Universal Remote Control Hampton Bay...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Remote control stopped working
Under the dome (where the electrical connections are) is the receiver unit for the fan. It could be that it is no longer working. Also the remote may have dip switches to change the frequency channel (sometimes located behind the batteries) check that these have not been changed or check they correspond to the receiver unit on the fan.
Jul 22, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
135 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
