Question about NAD C514 CD Player
Nad 514 can't find where the rubber belt is located. does somebody have a photo?
How do I set-up my NAD 533 turntable for initial use???
This Turntable looks nice. The belt goes around the two spindles [one big one small. the speed is adjusted by choosing which part of the small spindle you put the belt on. The upper platter rests on the big spindle and doesn't seem to be secured to it.
The counterweight should simply screw onto the back of the arm.
Manual can be found here: http://akdatabase.org/AKview/albums/userpics/10007/NAD%20533%20Turntable%20Owner's%20Manual.pdf
Jul 02, 2014 | NAD 533 Turntable
Timing Belt
in order to help you ? i need to know what type of sunny class it is ?
example : coup = B11 , sunny box = y 10 and so on , some have belts and some have chains for their timing .
Aug 29, 2017 | 1988 Nissan Sunny
Sound distortion with NAD T 514...
You are probably clipping in that midrange. Since the DVD player is fine and CD player is distorting: they are line level outputs, If you are running those through an equalizer- the equalizer should allow you add in a 10db attenuation.
If you are running them straight to the amp, The CD line level output should be about 1.5 volt peak to peak, it may be the line level input of your amp is only 1 volt and the DVD player simply has that level of output so does not clip..
Simply adding into the cable a 0.1 microfarad polyester capacitor for each channel should be enough attenuation to avoid clipping. The midrange is where you hear the most content in large part because that is the range that the human ear is most sensitive to. Which is why that portion clips. The DVD audio is actually recorded to the same specs as CD audio. You can confirm this by playing your CD disk in your DVD player. .
Sep 25, 2012 | Audio Players & Recorders
Disk drawer will not open
A small motor turns a belt, which then drives the gear that operates the drawer. Over time this belt stretches or breaks, and the drawer doesn't open. Replacing the belt cures the problem.
I've looked at the couple of belt catalogs I have, and nothing for NAD is listed. You'll need to measure the old belt circumference and thickness. Almost all of these are square belts, usually in the range of 2.5 to 3.5 inches circumference. If you're measuring the old belt, take off 10 to 15% since it has stretched.
A local electronic service shop may have a suitable replacement. Otherwise there are many sources online (MCM Electronics is one I deal with frequently here in the US). In a pinch, you can even use a small rubber band until you find the right replacement.
Hope this has helped. Thanks for using Fixya!
Feb 12, 2010 | NAD C542 CD Player
Security code for my home network
if you have a router you need to access the router's setup page. Contact DLINK and ask how to do that. or you can go herer www.portforward.com and locate the model of your router this will help you get into the router's setup page (choose any of the games or application to open port after that it will show you how to access the setup page of the router). The go to the wireless section and look for the security keys (WPA,WEP).
Sep 05, 2009 | D-Link DI 514 Wireless Router (DI-514)
Where can I get a belt for my NAD 5355 cd player?
Hi...
Try part# SBS3.0 from studiosoundelectronics.com
or a similar part at mcm electronics.
I just did one this week.
Mar 08, 2009 | NAD Audio Players & Recorders
NAD 533 Turntable
Just do a search in Google for "NAD 533 Drive Belt"
- OPTiC
Turntable Technician
www.1200s.com
Sep 01, 2008 | NAD 533 Turntable
D-link problem 2
Turn off your modem, turn off your router, wait 60 seconds. Turn on your modem , let it cycle, turn on your router.
Jul 17, 2008 | D-Link DI 514 Wireless Router (DI-514)
Nad turntable
the belt (aka rubber band) should be changed when it starts to slip
it is not whats causing the table to turn backwards. it's the motor or circut that drives the motor.
Jan 22, 2008 | NAD 533 Turntable
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
