Question about Electrical Supplies
Kohler marine generator 60 HZ where is the oil pressure sensor place
CarlGehrke
  • 169 Answers
SOURCE: kohler 12kw generator starts but shuts down after 3sec
Your gas pressure is too low and you may not have a large enough supply pipe. You need at least 10 inches of water column with the engine running to operate an LP vapor fueled engine. Because the engine is starving for fuel, its governor opens the throttle to WOT (so it goes to high revs) but there isn't any fuel to make horsepower with so the output voltage falls and the undervoltage alarm trips.
Carl
Posted on Dec 03, 2008
arealplumber
  • 33 Answers
SOURCE: Schematic
I looked for several minutes and this is what I found:
Kohler 13EOZD wiring diagram
I went to the Kohler site, entered the number and it cross referenced to the above number. The wiring diagram is on page 90.
Hope this helps!
Posted on Dec 05, 2008
mamicheddy
  • 79 Answers
SOURCE: Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Posted on May 07, 2009
  • 905 Answers
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
Posted on Jun 12, 2010
  • 259 Answers
SOURCE: I have a model #
Make sure oil level is up to par. When it shuts down take the wire off the low oil switch and see if it runs.
Posted on Mar 22, 2011
Testimonial: "very good, quick responce"
Have generator showing emergency stop code and will not start.
there are too emergency stop sensors on generators
one is over load
the other is low oil level in the sump (Low oil pressure)
That sensor is known to trigger and activate the emergency stop so check it out after you check the oil level in the sump
Feb 26, 2015 | Kohler 20resa 20kw Home Emergency Backup...
Where is the Oil sensor on Kohler generator
Not exactly sure about a Kohler generator, but I have seen the oil sensor on some small engines screwed into one of the oil fill ports in the block.
Sep 01, 2014 | Electrical Supplies
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
May 26, 2010 | Kohler Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
