Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is stuck in the pause mode
my duet washer is stuck in the pause mode.  we have replace the control board and also the front panel and it is still stuck.  do you have any other suggestions????
  • 8 more comments
  • cuttinitup5 Oct 31, 2007
    the door to my washer is locked since it is in the pause mode.  what should i do?
    We will try that.  Thank you :-)
    Is there a reset code for my washer?
    The reason I think that my pause button is stuck is because when I turn the machine on, the lights blink & when I try and hit the "pause/cancel? button it shuts the machine off rather than pausing.
    Please tell me what the correct part name is for the "door switch".  I will go ahead and order it.
    Thank you :-)
    What is the correct part name to order??  The only part I can find is called the "door lock".  Would that be the right part?
    Thank you for all your help :-)
    Do you think that I should order the door strike too?
    The model no is GHW9100LW1
    The serial no is CSM4604906
    The Type no is 100-AWM075/GY
    If there are any other numbers you need, please let me know.
    THANK YOU FOR ALL YOUR HELP!!!!!!!!!!!!!!!! :-)
  • cuttinitup5 Nov 01, 2007
    If it is going to be hard to replace, would you mind giving us instructions???  Thank you for all your help :-)
  • cuttinitup5 Nov 02, 2007
    THANK YOU SOOOO MUCH FOR ALL YOUR HELP!!!! We wished we would have posted to you first. It would have saved us about $450-$500 for unnecessary parts! Thank you for walking us through everything. We will definately keep this site in our favorites :-)
    Have a great weekend!
    cuttinitup5 :-)
  • 290 Answers
This sounds like a broken door switch. Open the door and look on the right side of the cabinet where the door latch goes in. About 4-5 inches above that there should be a small actuator that sticks out about a quarter inch. You should be able to press it in and out easily. If you only have a hole with nothing sticking out, the actuator is broken. You can break off a round toothpick and insert it in the hole, leaving about a quarter inch sticking out and gently close the door and see if the machine starts up.
Post back and let me know what you find.
Posted on Oct 31, 2007
  • 6 more comments
  • Michael  Lindley
    Michael Lindley Oct 31, 2007
    Remove the lower front panel from the washer and reach up to the bottom of the door latch and you will feel the latch release hanging from the bottom of the latch. Pull on it and it should unlatch the door so you can open it.
  • Michael  Lindley
    There is not a reset code. There is a diagnostic cycle you can run it through. I will look up the squence but I don't think it is going to help. The reason I think the door switch has failed is that nothing will work if the board doesn't sense that the door is closed, it will just blink the panel lights when you press start.
    If the washer is not in a cycle it won't pause, it will just turn off.
    If you have the lower panel off you should see the tech sheet that will give you the diagnostic checks.
  • Michael  Lindley
    Close the door
    Press control on
    Select drain/spin
    Select no spin by pressing the spin select button
    Push prewash button 4 times within 5 seconds  C:00 will appear in display
    If your washer doesn't have prewash button use rinse/hold button
    This puts washer into diagnostic cycle. It will actuate every component of the washer and check for failures. I don't think it is going to help with your problem since you have no codes displayed but it won't hurt to try it.
  • Michael  Lindley
    It is the door latch. The switch and latch are all one piece.
    Were you able to get the door open?
  • Michael  Lindley
    If the door strike is not broken I would not order it. I think the part number is 8182634 for the latch assembly. If you have gotten the door open so you can post the complete model number I will look it up and make sure.
  • Michael  Lindley
    Michael Lindley Nov 01, 2007
    Thanks for the numbers.
    Yes, what I called the latch is what is the doorlock in the parts diagram. The part number I gave you should be correct.
    Was the small actuator I described broken? If not we may need to do some checking, but you have already replaced the controls so there isn't much left anyway.
    Do you need to know how to replace the latch once you have it?
  • Michael  Lindley
    It is not hard, just a little aggrevating sometimes.
    Remove the wire clamp that holds the rubber boot to the front panel of the machine around the door hole.
    Pull the rubber boot off the right side so you can get to the latch.
    Remove the three screws that hold the latch to the cabinet.
    The latch is held in place by a plastic bracket, slide it up and out of the bracket and you can move it to the opening to remove the wire connectors.
    Install the new latch in reverse order.
    The thing to remember is to get the boot properly back into position over the lip of the opening.
    The aggrevating part is putting the wire clamp back on.
    I start it at the top and stretch it back on going down both sides at the same time. If you try to run it down one side you will pull the boot off the other side. It takes tough fingers to get it back on as it doesn't stretch easily.
    I can change a latch in about 15 minutes, but I have done several of them.
    If you need more help just post back.
  • Michael  Lindley
    Michael Lindley Nov 03, 2007
    Glad to be of help. The way the site works it is just a chance your question will be seen by an expert if it is posted on the free site. There are so many questions every day and most of us do this in our spare time. When you pay for the premium service, your question goes to a seperate list that everybody watches because we can make a few bucks. Hopefully you won't have anymore trouble, but if you do, you know where to come.
Washer stuck in pause mode
Check the door switch. I think you have posted twice.
Oct 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer will not start. It is in control lock mode for the last load of clothes that I wash
This is a very common issue. On the far right of the control panel their is a button "End Of Cycle" press it for 3 seconds to unlock the control.
If that does not fix it the user interface control board would need to be replaced. I can explain how to do this but think holding the button down will fix your washer issue.
Mar 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is stuck in "control locked mode" and won't start. It's normally in door locked mode. Whirlpool duet
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. .
Jul 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
GHW9100LQ1 machine stuck in control lock mode
Press and hold the "END OF CYCLE SIGNAL" button for three seconds and it will unlock the control panel. At least, I think that is the button for the Whirlpool Duet. If you look closely at the front panel, it will clearly state "Press and Hold for 3 Seconds to Lock" on one of the panel buttons (should be all the way to the RIGHT HAND SIDE). This button is designed as a safety feature to prevent small children from being able to operate the washer and inadverntenty getting locked inside the unit. If holding the button fails, unplug the washer for at least 30 minutes to reset the computer. I hope this helps.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer stuck in Drain mode, flashes same time, can't unlock control or pause/stop
ck to see if any water in drum if so possible pump clogged ..remove bottom panel pump will have clean out port with large knob turn counterclockwise ..expect flood if water inside but can't be helped if washer is on pedistal open drawer and try setting bucket underneath and have towels handy..after cleaning reinstall port cover and try again..if no water in tub try unplugging hold power button down 20-30 secs and reconnect still have problem door can be unlocked by removing bottom panel and pulling small tab just below lock assembly from underneath
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet is giving me a dl error or F11. The door will not unlock and my clothes are stuck in the washer.
F11 is a communications error between the main control board and the motor control board. You can first try to unplug the washer for a few minutes. Plug it back in and see if it will reset. If not one of the two control boards may be bad. Another thing you can try is to unplug all the wiring harnesses on both boards and plug them back in. It could just be a loose harness. The main control board is under the top panel in the back. The motor control board is behind the bottom panel on the left.
Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Electronic control panel stuck on Whirlpool Duet Sport Washer
it looks like the panel switch is brooken . if you take the panel off and see if the may get stuck.
Feb 16, 2008 | Washing Machines
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
Oct 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
