Question about Rusk CTC Technology Digital Ionic 1.25-Inch Str8 Iron Hair Straightener with Sol-Gel Technology
Broken cord just wondering if its possible to replace an electrical cord and if so how would the straightner come apart
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Just stop working. seems as if no electric power is reaching wherever it is suppose to. Iron is about 2 years old.
Those types of problems are usually one of two things... the cord where is enters the iron, the wires are broken. Or the thermostat has gone bad...
The iron will need to be taken apart and the wiring checked witha meter to find the problem for sure...
heatman101
Sep 27, 2011 | Euro-Pro Shark GI490 Iron
My wife has a Sunbeam iron handed down from her Grandmother so it is possibly fifty years or more old. It is a model A-4. The iron works well. I just want to replace the cord. How do I take it apart? I am...
try to open the terminal box then loosen the screw for line 1 and then the line 2 if you replace the cord see to ti that you wire installed is the same size on old wire.to avoid over loading.
Feb 25, 2011 | Sunbeam Irons
My Conair Proshine Straightner won't warm up, although the light is on. How do I fix this? ... hot plates not heating and the light says its warming up but the hot plates won't heat up
Most heated hair appliances are protected by a thermistor that will fail if overheated. These are small, about 1/2" long, cylindrical in shape with a pointy end and a wire coming from each end. When they go bad, they do not conduct electricity (zero ohms on a meter). There is a three digit number on the side that is the shutoff temperature. You can get these at Radio Shack.
Don't bypass this safety device.
Jan 07, 2011 | Conair Professional Ceramic Hair...
I have to jiggle the cord for the iron to heat.
The cord is broken right where it eters the iron...
Take it apart, mark the wires, cut the cord bach 6 inches and reattach it...
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Aug 18, 2010 | Rowenta Irons
Steam iron is not heating.
Yes you most likely can, they are very simply consisting basically of, a switch, a thermal fuse, a thermostat, and an element.. all wired into the Phase wire, the neutral, is simply the return. Take it apart and draw a diagram of how it all goes together and reverse the procedure.
May 09, 2010 | Irons
I have a DX 6700 that does not come on when plugged into the outlet.
Hi.
Either the wiring to AC power line is broken or the heating element is broken.
The heating element is tested taking apart the iron, disconnecting element contact, and reading impedance on element contact with a multimeter set at Rx1. If the element has no continuity (circuit open), then the element must be replaced.
If the power cord is fused (like for example in UK), check also the fuse in the power cord, try replacing it.
Regards.
Jan 17, 2010 | Rowenta DX6700 Iron
Moded cs327 wont turn on any more
FIRST CHECK PLUG FUSE HAS NOT BLOWN , THEN CHECK ELECTRICAL WIRE FOR ANY BURNS OR BREAKS.
Oct 27, 2009 | Conair Infiniti Instant Heat Ceramic Hair...
The electrical cord is seperating from the base of the iron and exposing the cord. The plastic covering is in parts. Can this be repaired?
You can repair this yourself but you will have to take the handle apart to access the power cord inside the handle. Just pull the cord inside and wrap with electrical tape to hold in place. Hope this helps
Jul 31, 2009 | Rowenta Irons
Broken electrical cord
if the wires aren't bare, wrap them in electrical tape. PLEASE RATE MY ANSWER.
Mar 07, 2009 | Euro-Pro Shark GI475 Iron
Rusk CTC Technology Digital Ionic 1.25-Inch Str8 Iron Hair Straightener with Sol-Gel Technology Logo
44 people viewed this question
Top Rusk Irons Experts
Are you a Rusk Iron Expert? Answer questions, earn points and help others
