Question about Electrolux Vacuums
We have a30yr old electroux that has been loosing vaccum. i took it apart and found a black foam rubber althrough the cannister and on top. i guessu i8ng that foam has something to do with the vaccum.
It is probably not worth fixing
    Genius:
  • Electrolux Master
  • 1,205 Answers
The foam may be a sound suppressor. Your vacuum may need a new hose. Old hoses have a liner on the inside that can collapse. Try removing the hose and see if you have good suction on the vacuum without the hose on. If you do it. Means the hose is bad or clogged
Posted on Apr 22, 2014
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Posted on Feb 17, 2008
  • 582 Answers
SOURCE: I have an old silver king cannister vaccum (R2-D2
I'LL DO A SEARCH ON LONE BUT THE MODEL NUMBER WOULD HELP
Posted on Aug 21, 2009
SOURCE: My vaccum started sparking ,
yes if it has a metal suction fan in the vac.or a moving beater bar brush. any moving metal part in vac.
Posted on Aug 13, 2011
Piranha floor steamer
I have a Pirahna 336 Floor steamerModel No.3001. after i fill the unit with water and turn it on , it dumps the water in 1 lot on the floor instead of turning it into steam. I took it apart and found on the base of the water cannister there are 2 orange rubber spacers approx 30mm wide x 10 mm thick either side of another Rubber washer 30mm wide x 9mm thick which covers the hole where i would expect the steam to come from. This Ribber washer has lost just about all of it's orange rubber covering as it has perrished. Can you advise me where i can procure a new washer and if by renewing this washer will it fix my problem?
Feb 19, 2012 | Vacuums
Need a picture or specs of the insides near motor
the big paper fiter attaches to the underside of the big black top piece of vacuum. there is a round plate and a nut you scew on to hold it. a foam rubber filter fits over it.
May 17, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Euro-pro model EP923H Steam Valve
I suspect you have done something on this by now but . . . You need to pry out a plastic cap/insert in the top of the handle. Beneath it are 1-2 screws to remove. The halves will then come apart. I have mine broken down but have no idea what to do now. It is not making steam. Reply if you have any thoughts.
Keith
Apr 08, 2009 | Euro-Pro EP923 Canister Steam Vacuum
I'm not really a technician, but I used to sell Filter Queens and was taught how to maintain them, and have tackled "fixing" some problems. I am a 71 year old great-grandmother of 8, but have good health...
i just took my old majestic apart to fix the motor
on mine, when you open the top of the machine where the exit hook up is
you take out those three screws
the top case comes off and you can get to those three screws and alot more of the motor as well
Good Luck !
Feb 25, 2009 | Filter Queen Majestic Canister Vacuum
Shutting off due to overheating
The foam style filters they sent you go in the top of the vaccume above the canister. There is a sticker in the back of the canister compartment indicating an orange lever in the top of that compartment. This releases a plastic retainer with the foam filter in it. Mine was so caked with dirt after 1 year of use it took a while to clean it up. I thought the vaccume was done for in only a year.
Jan 13, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Brushes not rotating on my Hoover Steam Vac Dual
The brushes are all connected to a single shaft. This square shaft is connected to 2 sets of gears and then another shaft which is turned by an impeller (suction from the vaccum pump is used to turn the impell and thus the brushes). There are 2 bearings that the impeller shaft turns on. It's likely these are rusted up and just need a bit of WD 40. Took me 30 min to take apart, lube, and put back together. Remember, its plastic. If things won't come apart, look for another screw. Mine was a brand new unit and the top bearing was rusted.
Sep 22, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover mach 3 cyclone vacuum shut off during useage. can't turn it on. cleaned it out and let it sit thinking overheated? this is 2 months old. help?
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Jul 12, 2008 | Vacuums
Oct 29, 2007 | Eureka Whirlwind 4496 Bagless Upright...
Vacuums Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
