Question about Garden
Stihl mm55 schematics
Have a yard boss multi cultavator start fine lots of power but a high pitch noise is coming from unit. Sat all winter ran if for a while seems to me better. Just wondering if I might have a bad bearing some where.
  • 28 Answers
Hi.. your starter one way drive spindle needs to be lubed....all the older briggs and stratton engines eventually have that problem...remove your starter cowling and you will see a metal square shaped part bolted to the engine which holds the flywheel onto the engine crack. that metal square drive spindle will rotate freely one way but won spin the other way...thats your starter one way drive...inside are about x6-8 roller bearing that lock it one way, so spinning it will start you engine, once the engine has started and is running the internal bearings will disengage due to centrifugal spinning forces, and you starter rope wont be ripped to shredds...its like a one way drive system...this part is supported on the cranck shaft thats spinning @ around 3600rpm...at very tight clearance on the inside...
IT NEEDS TO BE LUBRICATED...
a quick fix is to use WD40 or CRC with the extended long tube nozzle fitted to your can of lube. you will need to spray the lube at the end of your one way drive spindle...there is a small hole ,its there to be used as a oiling point....the squealing high pitch noise will be gone... wear eye protection when your spraying lube into small places....while your there spray some oil into your starter aswell....your couling should then be refitted using you 7/16 th spanner...i think there should only be x3 bolts holding the starter cowling on.....jobs done..you way need to lube it again next winter.....(dont disassemble the rotating drive spindle, the 6-8 bearings will fall out and reassembly is a pain....)
Posted on May 28, 2014
3 Suggested Answers
lemmingleejn
  • 173 Answers
SOURCE: I have a stihl 021 that doesn't want to idle, and
This is a timing problem.
Check the plug, and check magnete.
Then if you have to, remove the carb and replace the inlet gasket.
Good luck with that Scott.
Posted on Jul 26, 2009
snowghost1
  • 784 Answers
SOURCE: I have a Stihl .029
I have owned and use Stihl saws for the past 18 years and I have seen both these problems many times. as for the chain 'getting tight' -- when you go to adjust the chain, make sure you are lifting up on the tip of the bar as you set the tightness -- you should be able to only pull the chain away from the bar about 1/8th of a inch. now, while tightening the bar bolts make sure you still are pulling up on the tip of the bar,, and make sure the bar bolts are nice and tight -- not to tight though, the bolts that Stihl uses are a very weak point on their saws and I have broke more than just one. but make sure after one is tight that you tighten the other one and then give the first nut one more 'little' nudge tighter. new chains do have a break in period and they have been known to tighten up and loosen as they are running,, just keep your eye on it for awhile and thighten or loosen as needed.
now I am kinda confused on your next problem -- you say ' winter mix bar oil ' -- using this oil should not have anything to do with it stalling out, ( enless you are mixing bar oil with your gas ?? ),, make sure you are using Stihl 2-stroke oil to mix with your gas at a ratio of 50:1,, ( you can buy small bottles that mix with 1 gallon or a bottle that will mix with 5 gallons -- use 'em ). one thing that I have had troubles with when my saw wants to stall out is the fuel filter inside the fuel tank in the wrong position and is sucking air. also I have had fuel lines that crack and/or split and they **** air.
now the winter bar oil -- please,, I have been running Stihl saws in temperatures ranging from minus -5 to 100 degrees above and I have always used the SAME bar oil year round and had NO problems. on the side of the saw there is a bar oil delivery speed screw and you can adjust it to flow more or less -- your manual should show you the exact location of this screw,, make sure you clean out any debris that might be blocking the weep hole for the oil delivery. you need to make this adjustment with the bar and chain off the saw and you will see the flow of the oil and you can adjust to a good flow.
I am a firm believer in buying and using Sthil chainsaws,, I will never buy anything else,, they are great and out last any other saw I have used or seen,, and your Farm Boss is a great saw and should give you many years of trouble free use.
one suggestion that I would make real quick is to ' change your saw mechanic ' -- find one that has been ' WORKING ' on chainsaws ( not just selling them ) for along time,, someone that has your interest at heart and is there to help you,, not just to take your money.
(((( I am still laughing at the ' Stihl Winter Mix bar oil :-) )))).
good luck with your saw,, and if you have anymore questions about this please feel free to write me back here and I will do my best to walk you through what it is that you need to know and do. again - I have been using and working on chainsaws for most of my life.
have a great night,
c...
Posted on Feb 10, 2011
Why won't my Stihl FC 55 edger run?
First remove the module and clean the mounting areas to be sure the module has a good ground. Leave the ground wire off the module and run the unit. If it runs fine then you will have to kill the motor by pulling the spark plug or choking it down. If it runs fine reattach the ground wire and run again. If ran good without wire but not with then the switch is bad. If wont run good either way then likely a module.
Aug 05, 2014 | Stihl Fc-mm Edger Kit Sleeve Mm55 55 Yard...
High pitched noise coming from speakers after installing stereo
you may need to use a power line noise reducer or if useing amps a rca line noise reducer
May 10, 2010 | Boss BV9560 Car Video Player
Primer not pumping mm55 stihl yard boss
Your Stihl dealer should have a parts department where you can get a new primer bulb. Also check the fuel lines to make sure they haven't cracked or come off.
Apr 26, 2010 | Oregon Scientific Complete Carburetor for...
check your wires if they are too near some big power wires and move them away from these high powered wires or check your grounds and make sure its a good ground by scrapping the connection until bare metal. Also its a possibility rca's or wires are getting pinched or not fully connected.
Apr 05, 2010 | Boss BV9560 Car Video Player
High Pitched noise
I had a high pitch noise, didn't sound like it came from the "underside". Turns out it was one of fans that had little chips in the blades? My Audi dealer replaced it, and it's fine now.
Jul 28, 2008 | 2002 Audi A4
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Garden Logo
143 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
