Question about Xerox Workcentre 7345 Printer, Copier, Scanner
008-175 Bypass tray says there is a jam
2 Suggested Answers
  • 123 Answers
SOURCE: Xerox 7700. Paper is jamming at lower tray and
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Posted on Nov 18, 2010
My HP 2430 continues to jam on Tray 2 only. Tray 3 and Tray 1 (manual feed) are fine. I have replaced rollers and it continues to jam paper.
Common problem on this printer is for either the drive shaft for tray 2 to come lose or to break. Pull out the tray and try to rotate the roller. If it turns freely then the shaft is broken. The replacement procedure is too complex to describe here. If the roller does not turn freely then likely the pick solenoid has failed.
Oct 12, 2016 | HP LaserJet 2430dtn Printer
Paper continues to jam
check the paper actuate of the sensor if it o.k check the sensor if its clean
Jun 24, 2014 | Gestetner C7425DN Paper Feed Roller...
KMB BIZHUB 361 BYPASS JAM
Check your default on computers, via control panel might be set to default to by pass tray. Also check the paper selection on the copier ensure not defaulted to by pass tray
May 29, 2014 | Konica Minolta bizhub C351 All-In-One...
Paper jam when print from tray 2
There is Registration Sensor located near the bypass tray.Please clean the sensor or else replace the sensor or DC board.Orelse please check the pick up roller solenied switch( spounge in solenied may be torn out replace with another spounge)
Apr 05, 2014 | Genuine Konica Minolta Konica Minolta...
Imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Jul 04, 2010 | Canon imageCLASS MF5530 All-In-One Laser...
Misfeed detected. Correctly position the bypass tray. I have a BizhubC451 printer, and it makes a loud awful sound when I try to load paper into what I think is the bypass tray. HELP!
When you install paper in bypass tray you must touch the bypass button and tell it what size paper and type of paper you are using or it will jam everytime, let me know if this helps, e-mail me at dave.herron@att.net
Nov 18, 2009 | Konica Minolta Office Equipment & Supplies
Continues to jam from bypass and tray 1
doi have to buy yellow and magenta ink for mp 830 to work rip off
Oct 14, 2009 | Dell 1815dn All-In-One Laser Printer
Canon NP 6050 Copier
actually u hv not putted ur pblm correctly...
paper is jamming in ur machine but fm which tray u r taking paper...
n e way ...
1..if paper is comming fm down trays (i.e. 1,2,3,..or4) , try to clean the Pickup rollers of rubber material (at down side to the duplex tray or upside to the each tray) with some water and smooth cloth
2..if paper is comming fm bypass section then ur bypass pickup roller must be cleaned like above, or it must be replaced...
....try this and then also if not solved then place ur question again in detailed..
bye
Aug 15, 2008 | Canon NP 6050 Copier
Tray 1 problems
Most machines refer to the bypass tray as tray 1. You might want to make sure there is not a jam in there.
Jul 05, 2007 | Ricoh Aficio CL2000N Laser Printer
Xerox Workcentre 7345 Printer, Copier, Scanner Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
