Question about GPX CRCD6306DT Clock Radio
GPX CRCD6306DT Clock Radio Set Time and Alarm
I do not have a manual for the CPX CRCD 6306DT Clock Radio and I need to set the time and alarm. Can you help?
  • GPX Master
  • 3,554 Answers
SOURCE: GPX Radio Alarm Clock CD
I emailed the company and they sent back a pdf of the instruction manual to me the same day.
partsinfo@dpi-global.com
Posted on Nov 25, 2008
SOURCE: GPX clock radio clock question
I emailed the company and they sent a pdf of the manual back the same day.
SOURCE: How do I set the alarm on the GPX cr1807
Figured it out.
Posted on Mar 01, 2009
SOURCE: HSD128A projection clock came with chinese instructions
Here is the PDF of instructions. http://www.tinxi.com/download/88028_en.pdf
Posted on Jun 16, 2009
SOURCE: i have the gpx c208b
This clock radio has a switch at back marked "Auto/Off/On".
The 'on' position is the one you move the switch when you want to listen to the radio. The 'off' is the one you move it when you want your radio to be silent. And 'auto' is the one move to when you want the alarm to sound when the time reaches the hour you set it for waking up.
So, you must leave this switch in the 'off ' position all the time to keep the radio and alarm silent and move it to the 'auto' position whenever you want the clock to sound the alarm at the time you previously set it up.
Hope this info may help you!
Posted on Mar 11, 2011
Set time on clock radio CS238-5G
This is the way I worked it out, as soon as you've plugged in the unit, push the MEM button for a couple of seconds then push the PLAY/PAUSE button and hour will start to flash then use the arrow buttons to change hour, then push PLAY to change minutes. Once you've finished minutes push PLAY again. Not sure about setting alarms though and if you get stuck, unplug it and start again.
Mar 26, 2014 | GPX CRCD6306DT Clock Radio
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I have the gpx c208b digital clock radio. I recently set an alarm on it and it has been repeating everytime the time is near. i want to know how can i get it to turn off unless i personally set it myself....
Mar 11, 2011 | GPX C208 Clock Radio
I have a gpx hm3817dtblk shelf system and i was wondering if you can get the alarm to play a cd instead of the radio or if you can do either one and how? Or does it even have an alarm?
The manual:
http://www.retrevo.com/support/GPX-HM3817DT-manual/id/1183ag710/t/2/
Page 6>>>>
Setting the Clock
a. Press the STANDBY button until the unit is in standby mode.
When the unit is in standby mode, the STANDBY button will be red.
b. Press the CLK ADJ. button. The time will begin to blink.
c. Press the HOUR and MINUTE buttons to adjust the hour and minute.
d. Press the CLK ADJ. button to set the adjusted time.
Setting the Alarm
b. Press the ALARM SET button. The time will begin to blink.
c. Press the FUNCTION button to seleect CD, Radio, AUX, or Buzzer.
For Buzzer mode, the display will not show any indication.
d. Press the HOUR and MINUTE buttons to adjust the hour and minute.
e. Press the ALARM SET button to set the adjusted alarm time.
An alarm clock icon will appear on the LCD Display when the alarm is set.
Jan 03, 2011 | GPX HM3817DTBLK Shelf System
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
Nov 28, 2008 | Digital Products International Clok Smooth...
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Jun 06, 2008 | GPX CRCD6306DT Clock Radio
Feb 23, 2008 | GPX CRCD6306DT Clock Radio
GPX CRCD6306DT Clock Radio Logo
329 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
