Question about Yamaha HTR-5140 Receiver
Won't turn on all the way
Shows code ext decdr
I have a 95 Buick Roadmaster D blower motor will not shut off even if the key is out
sounds like a blower motor relay or control module. have it check first with your mechanic as the part for your car is expensive. goodluck
Mar 28, 2017 | Buick Cars & Trucks
What to do when drum heater does not work
you need to replace the drum and power suply as well
Feb 11, 2014 | Canon PTCH DECDR 6050/7550/9550-INST REQ...
Atwood G16-EXT won't stay lit
check burners and orfices for cobwebs if ok check pressure
Apr 20, 2013 | Atwood G16-EXT Gas Only XT 10 Gallon DSI...
We have a power wheels Mercedes and have charged it but it won't start
check the battery with a multimeter and make sure it is showing at least 12 volts
Jan 01, 2013 | Fisher Price Fisher Power wheels Cadillac...
Beyond Micro BMMDU2 wont show up on my laptop
might need to reset by turning both off
keep power for ext drive OFF
turn computer on
plug in ext drive usb(no power on drive)
turn ext drive power on
see if windows can ''see'' it now?
May 14, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
Vent won't change from floor to dash,defrost....ext.ext.
CHECK...
  • THE CABLE OR SWITCH WITH WHICH THIS IS CONTROLLED. ANY LOOSE SETTING CAN CAUSE THIS
  • APPLY SOME GREASE OVER THE VENT MECHANISMS UNDER THE DASH
  • PLS VOTE
Sep 24, 2011 | 2000 Chevrolet S-10
SX-50 Mitel wake up calls won't go through to rooms. Is there a way to reset or fix this?
Your Wake up device is in DND.... it either didn't hang up or it didn't answer. You should contact your vendor to have them check the RAD (Recorded Announcement Device).
Unless you know the extension number associated with it (the installers use different numbering from site to site and I couldn't even guess for you), you won't be able to clear the DND. If you do know the ext number... follow these instructions from the attendant console.
To apply Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number.
• Press the DND ON softkey.
• If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension.
• Press the EXIT softkey.
To remove Do Not Disturb on an extension:
• Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?.
• Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB.
• Press the DND OFF softkey.
May 18, 2011 | Mitel 9104-001-000 Power Supply SX-50...
Lines ring to a certain group and I need to change a phone from group 73 to group 72 - how can I do this?
From Ext 10 or 11>
Dial feature 00>
Hit the left intercom button twice>
The display will show "System Programming"
To remove the Ext. from group 73
Dial #502>
The display will show 'Group"
Dial 3 for group 73
The display will show "Extension"
Dial the Ext # of the phone that needs to changed
Dial 2 to un-assign the Ext from Group 73
To add the Ext. to group 72
Dial #502>
Dial 2 for group 72
Dial 1 to assign the Ext to Group 72
Dial Feature 00 to exit System Programming and save the changes
Be sure to ask me if you need more information
Mar 16, 2011 | AT&T Lucent MLS-12D Phone
Wharfedale LCD37F1080P and external surround sound
  1. hi here is what you do go into menu go to feature thento ext 2 out then press right blue button on remoteand find the ext you need make sure your tv volume is turned down make sure your surround sound is on and turned up wait and you will here your sound when you have the right ext i have hdmi lead in ext 5 so it ext 5 that will show in the feature menu i hope you find your problem solved allan
Aug 09, 2008 | Televison & Video
Yamaha HTR-5140 Receiver Logo
20 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
