Question about Electrolux Dishwashers
I have a dishled DX303WL. It runs through the cycle but the water doesn't heat up (washes cold) even on the hottest setting.
  • 400 Answers
There are several things it could be. To isolate, you could check the resistance of the heating coil. It should be very low resistance. If that checks okay, test the voltage while the machine is on it's sanitize cycle (on sanitize cycle because I am not certain if your machine heats on every cycle). If 110v is not there, the controller is the culprit. I hope this helps you track down your problem.
Posted on Mar 27, 2014
  • 641 Answers
SOURCE: Fills with water but won't wash.
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Posted on Aug 12, 2007
SOURCE: heating water on and does not finish washing
I have a SALTON DISHWASHER MODEL SDW12.I would like to find out why the water is not heating up. Is it possible that a fuse could have blown and if so where would the fuse be situated. Any other info would be greatfully recieved.
Thks,
Danny
Posted on Jun 18, 2008
SOURCE: not hot washing or drying
you can check for continuitry through the heater assy, possible its bad after working overtime for 5 yrs trying to heat cold water
Posted on Oct 31, 2008
djz83
  • 88 Answers
SOURCE: Not heating water
Is this an old or newer dishwasher many newer models will not bother trying to heat up the water if it does not come in hot enough there is a temperature sensor, if the water is cold heater will not come on because it will take it too long to heat the cold water.
Posted on Jan 11, 2009
Testimonial: "it was the temp sensor ,thank you"
  • 423 Answers
SOURCE: lg dishwasher never heats water
The LG 7811 dishwasher is supposed to even support a cold water (vs. hot water) connection. Then it will heat the water up to 120 degrees upon each fill cycle. This is not optimal and it adds much time to the already long full cycle. When you run the hot water at the kitchen sink until it is hot and then kick off the cycle, is the water hot at the beginning? It should be 120 degrees minimum and well under 140 degrees maximum.
Do you get any error codes on the display? Troubleshooting is possible, but recommend you contact LG service at the number in the user guide asap. Press for fast, free resolution to this problem. Please reply when you have gotten this fixed, explaining what fixed this nice, quiet dishwasher. Good Luck!
PS: When you get it running, do not use ultra-cheap dishwasher soap. Recommend Electrosol powder or cascade. Never use gel or tablets on this water conserving dishwasher.
Posted on Mar 31, 2009
My Roper washer will run through wash cycle then stops. Nothing will work for 40 minutes then I can put it on rinse then the cycle will complete. What could cause the stopping with nothing working then...
It could be that the machine is trying to heat the water in the drum, but is not able to for some reason. The timer is waiting for the water to reach temperature before advancing. Posssibly a broken heating element. This can happen even on a cold cycle as most machines prefer to heat all soaping water to about 30C regardless of the temperature setting.
Sep 13, 2013 | Roper Washing Machines
No hot water coming in during the wash cycle.
Hello Stephen Foster - Based on the symptoms you are describing, typically, the unit could possibly have a faulty timer, temperature sensor or water valve. Confirm that the holes are properly connected. Try resetting the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. However, if the issue persists, it is always a good idea to have a service tech properly diagnose your appliance.
Apr 15, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
My Inglis washer machine (#111-07) which we bought 2 weeks ago, doesn't use any hot water when set to the warm cycle (in between cold and hot), so i can only wash with entirely cold or superhot water...
Hi Elllie602 (!) from retired Englishman in SW France,
2 weeks old? Under guarantee/warantee? Get in touch with the vendor/shop!!!
Even if it takes only cold water for the warm wash (which is a bit daft- normally washers mix the hot and cold accordingly) and heats it, that is not how most hot n' cold washers work.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Whirlpool Washing Machines
The inside of my dishwasher is gross...slimy and brown. even after a cycle run wiht dishwasher cleaner and disinfectant. What can I do?
try cleaning it out with a rag with bleach on it Then run a rinse cycle through it just with hot water no soap
Jan 23, 2010 | Dishwashers
1994 Kenmore 90 series washer smells musty
If you do not use a hot water cycle every so often it can contribute to the build up of mold or mildew inside the washer drain lines, pump and tub.. This is a common problem for those that only use cold water cycles. The detergent alone sometimes is not enough to kill bacteria. You also need the heat from hot water. I would recommend that you run a cleaning cycle on the hottest setting you have about once per week as a preventive measure. Add some bleach to the water to kill any existing bacteria. NOTE: This may take a couple of wash loads before you notice a difference. If you wish to conserve by not wasting water and energy by running an empty wash tub every week, switch to washing your whites in hot water with a little bleach to keep them brighter. This will kill bacteria in the washer in the process. I hope this helps you.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
I have a new Frigidaire FDB1050RE diswasher. I ran it for the first time set on normal wash and pressing both the Hi-temp wash and heat dry button. This cycle is supposed to take a total of 89 minutes to...
It should still work pretty well but you probably can't use the high temp wash because it will take too long for the dishwasher to heat up the water enough to satisfy the high temp washer thermostat. If the thermostat's calibrated closing temperature isn't reached the dishwasher will just keep running. One thing you should do to improve washing results is to run the nearest tap (probably the kitchen sink) until the water is at it's hottest and then run the dishwasher so the first fill will be hot rather than warm.
Oct 09, 2008 | Frigidaire Dishwashers
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Dishwashers Logo
60 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
