Question about Kenmore Washing Machines
Kenmore oasis washer won't turn on
When washer is plugged in there is a beep and a flash on the control board and nothing happens no light turn on
  • 400 Answers
Mine got some moisture on the board, then arched between print runs. I had to break the print runs and then bypass the arc point. I thought I was in for a new control board, as when I first tried to repair it I did not clear the arc point, and therefore it still did not work. I hope this steers you to the solution for your problem.
Posted on Mar 27, 2014
SOURCE: i have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Posted on Mar 18, 2009
  • 7 Answers
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Posted on Dec 06, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE. I keep getting a F2 error
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: my kenmore elite oasis washer kept beeping during
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
The part number for the user interface for this model is 8564374.
You can order this part from www.SEARSPARTSDIRECT.com
The procedure for replacing this control board is shown in the images below.
NOTE: You should only attempt this procedure if you are completely confident in your technical ability to safely execute the process.
Follow electrical safety guidelines. Unplug the washer before accessing internal components.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the washer first.
http://media.fotki.com/1_p,wkgbsdrbswtkdqwxgtqsskgwtqkq,vi/ksgtwdgrtxkrrffsdss/1/1303472/5961857/image29464img-or.jpg
http://media.fotki.com/1_p,sqrbbsbrrbwrbdtxgtqsskgwtqkq,vi/kbqtdwdswxkbswddwbg/1/1303472/5961857/image23056img-or.gif
Posted on Sep 30, 2010
Macmarkus
  • 2605 Answers
SOURCE: On a Kenmore Oasis topload
Hello, Welcome to FixYa. I can't seem to access any previous post dialog that may have taken place but I'd like to help if you can fill me in on whats taken place to this point. Sorry to hear you replaced the control for nothing, F51 has nothing to do with a control board issue. The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how. I'll wait for you reply to see whats been done or suggested and checked to this point. Regards, Macmarkus :)
Posted on Apr 06, 2011
Kenmore Oasis washer model 110.2709 - Clean washer light is on and machine beeps, after we run the clean washer cycle the light and beep does not clear out. I can't get the washer to run a wash cycle...
Ok this is easy there was a defect on all of them don't worry easy and free fix I want you to call this # (800) 659-7026 they will get your info and send someone out to replace control board. Free. In mean time I want you to unplug washer because it's dc motor it still has juice so hit power then stop tell the lights don't come on plug back in and enjoy the temp fix tell they come out to fix it. Don't worry I sell them and I have one and it is still a great washer it was just the first one out of it's kind so it had flaws but sears is taking care of it's customers.
Apr 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis no error code keeps beeping low -loud
If its the main board that you are having an issue with, honestly i will suggest to get a new one instead, might cost you as much as buying a new one if you are going to have it repaired.
May 14, 2008 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Takes 3-4times to clear the F-1 problem and then stops
They had a recall on this machine for that control board. I would contact Sears again to get this corrected. Plus that control board should of had a 2 yr warranty on it. F1 is a code for a control board communications error. It also has software updates for other "known" issues. Hope this helps
Jun 09, 2009 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore elite oasis washer will not turn on. I
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Elite Top Loading Washer with an F2 error
The F02 error code indicates keypad/user interface failure. Most of the time, this is caused by a problem in the keypad/user interface. It can sometimes be caused by a failed control board.You could have an intermittent problem such as a stuck key or contact. As long as the F02 is not displayed, the washer should work normally. You can continue to use it when the F02 is not displayed. It is still safe to use the washer.
Sometimes this problem is caused by a loose wiring harness connection between the keypad/user interface control board and the machine control board.
The F2 error code on this washer indicates a stuck button on the user interface control board. The procedure for accessing the control boards on this washer is shown in the image below. I recommend unplugging the washerand checking the wire harness connection from the user interface control board to the machine control board. Try unplugging the connections and then plugging them back in a few times. Make sure that they are plugged in correctly and then reassemble and test the washer. If the F2 is still displayed, then the user interface control board will need to be replaced.
CLICK ON THIS LINK TO GET THE INSTRUCTIONS HOW TO REMOVE CONTROL BOARD:--
http://media.fotki.com/1_p,wfbgkftgqtgssggxgtqsskgwtqkq,vi/gdqwksfbdxggskbksbb/1/1303472/5961857/image8028img-or.gif
You can order a new user interface control board from the Sears PartsDirect website or from----------
www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 12, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
This is a common problem with the Oasis. The problem is the User Interface Control board behind the control panel. There's a relay on the board that shorts out and causes the washer to randomly (and constantly) beep. This can also occur with the washer turned off. Since the circuit board is not serviceable it is recommended that you replace the control board. Searspartsdirect.com carries replacement parts for your washer. Just type in the model number and search under the console heading for the user interface board. If you are usure which part, I'm talking about, please post back with your model number and I can assist you. I hope this helps.
Aug 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Power trouble with Kenmore Oasis HE 4, Model # 27082601
More than likely it is the control assy again, make sure the unit has a good ground before replacing the control assy.
Sep 17, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Beeping
That annoying beep you are talking about is the Cycle On/Off alarm, right? If so...this is a common problem with the Oasis. The only cure I know of is the replace the Interface Control Board behind the console. Now, you mentioned that the machine started up AFTER you removed the console (?), top (?). That sounds like you have a loose or dirty connection between the Interface Control Board and the Main Control Board. There should be a single plug in harness going to the console to the Main Control Board. With the machine unplugged, try disconnecting the harness at both ends and cleaning the contacts. This may resolve what I believe to be a connectivity issue, and may even cure the annoying "beep". However, I personally have yet to find an easy fix for the alarm problem. It is caused by a defective relay on the Interface Control Board, and the board is not serviceable. That is why is has to be replaced. I wish I had better advice for you than that. Sorry...I hope this helps some.
Aug 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
18 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
