Question about HTC Cell Phones
Orange light blinking mean
When I put my HTC to charge I get an orange flashing light instead of a solid one. It couldn't be the charger because I use the same one for my HTC 3d and it is currently charging. Why is this happening?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 80 Answers
Just because it works on another phone doesnt mean its not the charger.
Posted on Apr 03, 2014
SOURCE: Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Posted on Jan 10, 2009
270rexton
  • 762 Answers
SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Posted on Sep 25, 2009
Testimonial: "holy crsp it worked thanx:)"
jerseymark
  • 358 Answers
SOURCE: My battery does not charge
Hello, why the phone is not charging is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
And also if the battery still doesn't work that means the phone memory is weak and it will need to be flashed to restore back the phone memory.
What you will need to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Posted on Sep 12, 2010
rak_yel
  • 58 Answers
SOURCE: my HTC inspire 4G won't turn on or charge. the
Was going through this article. It might help:
http://community.htc.com/na/htc-forums/android/f/113/p/9281/40043.aspx
Posted on Aug 26, 2011
  • 118 Answers
SOURCE: htc rhyme not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jul 27, 2012
Blinking blue light
if you have your device hooked up to it, i believe it means it is charging, as i understand it this particular charger can charge multiple devices, the older models of this unti had defects and needed to be fixed, normally if everything is charged, the blinking light would go away and a solid light would appear.
Nov 04, 2013 | POWERGEN Dual Usb 3.1a 15w Travel Wall...
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
My phone wont turn on and when I try to charge it, it flashes orange on and off instead of showing a solid orange light.
First thing to do is try to replace battery for a test,usually when phone is often used,it can easily discharge like using wifi or any,then simultaneously charger is plug in.this will damage the battery and can be easily drained.
Aug 06, 2011 | HTC Evo Shift 4G (2 GB) Smartphone
Hi I have a sony cybershot camera that i bought online from amazon a month ago. I just put the battery to charge this afternoon and then after a few minutes i saw that the orange light was blinking instead...
Most chargers blink while charging and become "solid" when the charge is complete.
Set it up again and let it blink for up to eight hours.
Jun 28, 2011 | Cameras
Hi, what is the flashing light on my HTC wildfire screen ? sometimes it's flashing and sometimes not so could you please tell me how it works normaly ? thank you
i think you mean the led above the screen. it is a led that means a lot of things
like: orange - recharging green - full battery red - low battery
there are more things like notifications for text messages (all apps can make ir blink for their own reason)
hope this helps
Feb 20, 2011 | HTC Wildfire Cell Phone
What does blinking orange light on the phone mean?
Solid amber light when the battery is being charged.
Flashing amber light when the remaining battery level reaches below 10% htc has had some problems with batteries,when charging, if you are getting the flashing amber light feel the back of the phone. if it is feeling hot you may have a bad battery. hope this helps.
Jan 23, 2010 | HTC Touch Cruise Smartphone
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Camera will not turn on...charged battery but the charge light blinks instead of staying solid
If battries still blinking , chances are that the battries are buggred...try new battries after fully charging...this is cheaper option to try before trying to open the camera..
May 20, 2009 | Casio Exilim EX-Z77 Digital Camera
Cell Phones Logo
193 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
