Told set up is OK. Play Netr flix. The then get messahge network is down. According to Century Link my wireless is working correctly. What is going on?
Internet Connection status. Connection canniot be confirmede. A network error has occcurrede.
    Champion:
  • 329 Answers
Your end of the network is up, but the Netflix end is down. Just wait a while and it should be back up or else they'll (Netflix) have a lot of angry customers.
Posted on Jun 11, 2014
Gives error "code 10"
Hi
error code #10 is shown when the device can not be properly addressed and started.
OK, here is what we are going to do. First, uninstall the device from
Device Manager (Start-Run-devmgmt.msc). Now, uninstall the D-Link
Software from Add/Remove Programs in the Control Panel. Now reboot,
then get the latest drivers from D-Link's website. I am linking you to
the drivers for the D-Link DWL-650 (not DWL-G650), but you need to make
sure you have the exact model and firmware version correct. If it is a
different version, go to <a style='text-decoration: underline;' href="http://support.dlink.com" target="_blank">http://support.dlink.com</a> and use the drop down
menus to pick it.
Once that is installed, we are going to disable the Wireless Zero
Configuration Service. Click Start-Run-Type services.msc and click OK.
Scroll down to the bottom, right click on Wireless Zero Configuration
and click Properties. Stop the service and set it to disabled. Click
OK and close that. Now open the D-Link Configuration Utility and
configure it from there.
Jul 08, 2011 | D-Link Computers & Internet
Everytime I try to connect to the internet it wont let me I wanna watch net flix
Sorry to hear your having problems with your wii. You can connect the wii via wifi or wired with an adapter. Check out Nintendo's tutorial for instructions on how to do this:
http://us.wii.com/connect/
You basically goto:
Wii Options at the bottom left corner of your home screen, then Wii Settings, Click the right arrow to goto the next page, Click Internet, Click Connection Settings, Click Connection 1, Click Wireless Connection. Click Search for an Access Point. Click OK to view the found access points. Select the Access point for your wireless internet, enter your encryption key, click Ok and then OK again to save settings, and then OK again to test the connection.
If you have done all these setups make sure your selected network and encryption key are correct. If you have an error code search on that error code online.
Apr 29, 2011 | Nintendo Wii Console
How do i connect my wireless d-link to my internet?
Using a LAN cable connect the router to your internet modem. Usually use LAN port 1 on each unless indicated otherwise.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
The using the setup wizard, configure your WAN according to the requirements of you modem PPPoE, Dynamic, etc. In some case the router will sense the correct set-up.
Feb 07, 2011 | D-Link DIR601 WirelessN 150 Home Router...
DIR-615 Wireless Router: i have a d-link wireless router dir 615 that i've ...
if youve changed the password on the router since the other computers logged onto the network, then you need to delete the network history from those computers.
Otherwise those laptops will be trying to connect to the network with the old details.
May 16, 2010 | D-Link DIR-615 Wireless Router
Wireless no longer accesses router
OK try this go to that PC, go START>>RUN>>service.msc (enter) Now when services window comes up, scroll down to DHCP, set to OFF & Disable, reboot, now try again. Sometimes just a Turn it ALL OFF, and ON again and most often it will sort itself out., IF it was working OK prior. You could always run the "Connect to internet Wizard" again, and do that. Also go into router and ensure that DHCP, is set to ON in the Router. Sometimes, a simple re-setup will get it all working again too.
Apr 01, 2010 | Belkin F5D7010TTSN-W WIRELESS 802.11G...
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
How do i reset our wireless network setting on my playstation 3?
On the back or side of your router their is a button that resets it to the original factory settings. Hold that button down for 5 or more seconds then release it.
Everything should be back to normal, also you will have to reconfigure that router
On the bottom of the router the user name as password might be------> user= Admin Pass=password
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
Cannot pick up internet with WBR1310 wirreless Router
Hi lola,
You may want to check your network settings.
Go to start->control panel-> network connections. Right click on your wireless connection and select properties. A new window will appear, under "This ocnnection uses the following items" in the general tab, scroll down until you see Internet Protocol TCP/IP.  Make sure the tick box beside it is checked.  Select it, then click properties.
Another window will now pop up.  Make sure that Obtain an IP address automatically, is selected, and Obtain DNS server address automatically is selected.  Then click OK, and OK on both windows.
If this is already set correctly then the most likely cause is that you have entered the wrong wireless authentication key (password) for the encrypted network.  Make sure that you have entered all of your username, SSID, and password information for that wireless connection correctly.
You also may want to check that you are in fact attempting to connect to YOUR wireless network (you may have multiple wireless networks in your area).
Hope this helps, and please don't forget to vote/rate!
Mar 12, 2009 | Computers & Internet
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox 360 Console
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
