Car start drive then battery dies
I'm not certain I understand the problem, but it sounds as though the battery is not charging properly. Check it yourself, or have the charging system and battery checked. With the engine running the battery voltage should read about 14 volts. If it is much lower, the charging system is not working. If the battery goes down with the car just sitting, there is something drawing more current than it should. Easy things to check are for a glovebox light, overhead light, trunk light or underhood light that does not turn off. Normal draw with everything off, after sitting a few minutes, should be less than 100 milliamps. I hope this is helpful.
