Question about GE Logic 200 Pro Series Ob/gyn Us System Mtz 6.5 Mhz & Cbf 3.5 Mhz Transducers
GE logic 9 ultrasound unit problem
Screen frozen. Unit beeping. Cannot restart as will not turn off, even if I unplug it.
    New Friend:
Did you ever figure out what the issue was. I'm very curious as my ultrasound machine is doing the same thing.
Posted on Sep 26, 2014
I have a GE triton quiet power 2 dishwasher, and the "normal" wash light will not stop blinking/beeping. Because of this, it will not start any cycle, just keeps beeping and blinking. Please help!! Ive...
Hello Shayla Moy!
What an annoying situation!
You were wise to try a hard reset by plugging and unplugging. Often a solution with modern appliances with electronic controls. See, control, alt delete ??.
The troubleshooting page of your manual will likely translate the desperate message your machine is trying to convey, or a call to GE service, although they often just want to schedule a visit by a tech.
Unfortunately, this sounds like the "blue screen of d$&th", since you have already plucked the low hanging fruit.
A final thought. Unplug the unit and how far you can find your way below the screen at the bottom of the tub. Maybe something large, like a piece of broken glass has jammed the soft food grinder causing the unit to shut itself down. Of course, if that were the case, the unit would start briefly every time, then display the symptoms you describe.
Also, grunge buildup is a common issue. If you have an accessible water level float switch, remove that and inspect. Unfortunately, it may be external to the tub, on the side.
Is there water in the tub or did the unit run a full cycle last go?
All the best.
Nov 22, 2014 | Dishwashers
Bose p1 turns on but only first touch works then freezes
If you've done the complete walk around i/e--unplug from wall/remove batteries takes bout 1/2-to-1 hour don't be in a hurry then go bac & reset--if no go then your room interfac M-1 needs repair..1boseguy@gmail.com
Apr 16, 2017 | Bose 023795 LCD Touchscreen Remote Control
Was in the middle of a game. Loud buzzing sound came on, game froze up, power button and reset button will not work, bu disc will eject. Screen shows frozen game and still buzzing with no disc in, cannot...
Disconect all the wires from the unit and leave for atleast five minutes. You need to even unplug the power cord from the recepticle in the wall or power bar. The unit should reset itself and hopefully turn back on clear of what was locked on.
Dec 10, 2010 | Nintendo Wii Console
Buttons not working, beeping sound
HI. This is a control fault beep. Kindly unplug, or shut off the appropriate circuit breaker for five minutes. This will drain the main control, and reset the logic chip. Once the five minutes has passed, re-introduce power to the unit, and try to operate the dishwasher normally. If the error continues, replace the control sector asap.
Oct 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Blinking lights and frozen unit, won't unlock or do anything
Ours did the same thing. It had not been installed corectly. Try pushing in on the door then push the re-set button, it can take up to 90 second's to re-set, if the door isn;t fully shut it will continue to beep. If this doesn't work, unplug the unit for a few minutes to see if it will re-set. Good luck. We were up most of the night trying to find the owner's manual. Finally found 1 on GE's web-site.
Sep 07, 2009 | General Electric Adora GHDA670N Built-in...
User manual needed
i wNT GE LOGIC BOOK XP ULTRASOUND MANUAL
Mar 11, 2009 | Ecg Toshiba Famio 8 Digital Ultrasound...
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a twin pact 100 connected via RGB to mobile ultrasound unit.
Please check the videosettings on the ultrasound scanner.
(Videosettings)
Maybe this is for your purposes not correctly setup.
Think of : video interlacing, Frame/Filed, NTSC/PAL.
Ofcourse the same thing counts for the Twin Pact !
Question: what type is the Ultrasound Unit ?
Brand/Model ?
Oct 31, 2008 | Canopus TwinPact 100 (77010136100) Video...
Frozen Display
It may be that the internal firmware has become corrupt, or there is a fault on the main processor board, or with some other area that is effecting the system processor, and thus the system is not able to function properly.
Call the service rep for your microwave oven and bring it in for an estimate.
Jerry G.
Apr 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Logic 200 Pro Series Ob/gyn Us System Mtz 6.5 Mhz & Cbf 3.5 Mhz Transducers Logo
143 people viewed this question
Top GE Science & Laboratory Experts
S J Parkin
S J Parkin
ray gallant
Tom Chichester
Are you a GE Science and Laboratory Expert? Answer questions, earn points and help others
