Question about Hyundai ImageQuest P910 Plus (White) 19 in.CRT Conventional Monitor
QuestMaster Q770 Monitor
The Monitor does not come on...the light is orange. When I press one of the setting buttons it changes to red and displays the message "Off Mode". How do I switch to On mode?
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
  • 432 Answers
SOURCE: Standby mode
Check the video connection the video card. You can try another monitor to see if it does the same thing. The video card could be bad.
Posted on Jul 16, 2007
SOURCE: Analog Power Saving Mode
When my computer tries to boot up, the monitor remains blank. The monitor works on another computer, the power supply has been swapped with a working one, and failing any solution, the motherboard has been replaced. Nothing makes any difference.
Posted on Feb 07, 2008
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 103 Answers
SOURCE: Cant detect 1600 x 900 on control panel - display
You need to install the driver for your samsung sync master 2033, so the the graphics will improve or updated.
Posted on Jun 04, 2010
  • 5 Answers
SOURCE: receiving a message on second
sale your monitor or throw it out of your home
Posted on Aug 19, 2010
0 characters
1 Points
Acer p223w monitor does not turn on
Try a different monitor, check the connections to the pc. When the monitor light changes to orange, press the spacebar to see if the light changes back to blue. Your pc power settings might need to be re-adjusted, is the pc going to sleep or hibernating too soon?
Jan 02, 2014 | Acer Computer Monitors
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computer Monitors
LG20" monitor. Suddenly a red
Try to reset it
Scroll through the menu options by using the up and down arrow buttons located just under the "Menu" button. Scroll down to the "Setup" icon, which looks like a big cog. Press the "Auto/Set" button to access the Setup menu. Scroll, using the down arrow, to "Factory Reset." This setting is located at the bottom of the Setup menu. Press the "Menu" button on the right side of the monitor. This will bring up the On Screen Display. If nothing happens when the "Menu" button is pressed, press and hold it for several seconds to unlock the On Screen Display. Press the "Auto/Set" button to choose "Factory Reset" and then press the down arrow to reset the monitor.
Jul 23, 2011 | LG Computer Monitors
I don't know how to increase the volume
OSD Menu Functions
All the function settings for the LCD monitor are controlled via the control keys located on
the bottom part of the front panel. To display the OSD main menu, press the “Menu”
keypad button on the control keys2.gif. (Note: The OSD menu display will disappear
automatically after approximately 10 seconds, if no action is taken.)
The LCD2.gif monitor has been adjusted to optimal settings before shipment. Adjustments to
the monitor settings can be made using the OSD menu.
• Press the “Menu” button to display the OSD.
• Press the ▲ or ▼ button to select the function to be adjusted.
• Press the �� button to access the function to be adjusted.
• Press the ▲ or ▼ button to select the sub-function to be adjusted.
• Press the �� or �� buttons to change the current setting of the sub-function.
• To go back to the previous menu, press the button. Changes are saved
• To exit the OSD menu press "Menu" again. It automatically will save any changes
that have been made.
If this is helpfull; please indicate so.
Nov 11, 2009 | Westinghouse LCM-19v5 Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
The regulator ic is lm7812 series lm no matter replace it or 12v regulator
Nov 26, 2008 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Side Buttons - Not Responding (wrong input?)
These buttons can stick, when you press the buttons do they click
if not then it is stuck in.
Jan 27, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Open Questions:
See all Hyundai ImageQuest P910 Plus (White) 19 in.CRT Questions
Hyundai ImageQuest P910 Plus (White) 19 in.CRT Conventional Monitor Logo
24 people viewed this question
Top Hyundai Computer Monitors Experts
 Mike M
Mike M
Bob Sloan
Are you a Hyundai Computer Monitor Expert? Answer questions, earn points and help others
