Vokera linea 24
Loud continuous vibrating whirring noise when in heating mode.
  • 1,162 Answers
Most of the time the air passage is clogged with dust. If you can change the air filter if it has one, or clean the airway where air enters an exits the unit. The motor fan is struggling to move air that is where sound is probably coming from.
Posted on Mar 27, 2014
4 Suggested Answers
SOURCE: My vokera linea ag plus domestic hot water cycles
I have the same problems, did you manage to get it fixed and what was wrong?
Posted on Mar 08, 2010
luxfargo
  • 14 Answers
SOURCE: When it comes on, it vibrates so loud can hardly hear over noise.
It sound like your fan is loose and needs to be tightened. Remove the four screws on the bottom of your unit, slide out and tighten the screws on top of unit. If you need to get in the unit remove the back screws, you will have to remove the temp sensor to remove the back panel. Remove the side panels on both sides. You should be able to get to the fan.
Posted on Dec 02, 2011
  • 2597 Answers
SOURCE: vibrating central heating boiler
If it sounds like a train it needs a sytsem flush is sluge in there .
Posted on Nov 10, 2012
Roaring noise front end
sounds like wheel bearings
Sep 01, 2013 | Mercury Cars & Trucks
How do you reset the vokera boiler
where is the reset button on a linea 24
Jan 09, 2010 | Heating & Cooling
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Apr 21, 2009 | Heating & Cooling
Vokera linea combiboiler error code CO
It's got nothing to do with carbon monoxide. CO means the boiler is in combustion test mode, that's all (and in this case -- long since fixed, I imagine, but other people will no doubt find this page in the future -- failing). Vokera could probably have made this clearer, but hey.
Dec 23, 2008 | Water Heaters
HEATER MAKING LOUD NOISES
Check the draft inducer motor for any partial blockages or dibri.
I've seen sticks, birds nest particles and pieces of deteriorating fan blades (squirrel cage type fans) cause this.
You might also find that the inducer motors bearing are going.
If its a loud vibrating grinding type noise, I'd suspect bearings or missing pieces of the blades. (unbalanced)
If it's a clanking type noise I'd suspect loose items hitting the fan.
The inducer motor will only operate right before and during burner operation, while the blower motor can operate at any time depending on your setting.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
