Question about Philips FR911 Receiver
Philips FR911 not output , only after volume blast
Hello i get no output on my FR911 after i just turned it on. I have to turn up the volume to about 21 and the i've got sound. I can turn the volume back down again and it keeps working.
Doesn't matter if i use speaker channel A or B, olsa changed speakers and cabels.
Thanks in advance
  • 4,234 Answers
These units have a relay that "turns on" the speakers. If the contacts are a little corroded, the symptom you describe will occur. Replace the output relay and the problem should go away. This part will cost around $15 or so. Dan
Posted on Jun 15, 2009
  • waltweber Feb 03, 2011
    Any chance anyone has a part number or other identifying info? The unit is my son's, a 7.5 hour drive away....
It stopped, while not being used.
Possibly taken the fuses out suppllying the power stage.
Mar 12, 2014 | Sherwood RX-4109
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
I have the xdvd710 when i start my truck up volumn is blastin every time!!!!! how do i get it to stop?????
The dual XDDVD710 RADIO has a volume memmory (it seems), it will go to the last volume setting that it was set to, not play to,(supposly to keep it from blasting you when you turn it on and you forgat u had the volume on blast).
To set it,
1 turn radio on,
2 turn the volume to desire Level you whant it to go when you turn it on (other Levels besside BLAST hopefully) ,
3 push the volume button in, that should do it.
Now you can play your music loud and should you forget that you had it on BLAST (to over come road noise) when you last played your radio, it should start at the preset volume.
Dec 09, 2010 | Dual XDVD8170 Car DVD Player
No audio from mini input jack on Pioneer SupertunerIIID 50w x4
The mini jack was not designed to work in the manner in which you are trying to use it. The stereo output is always going to be at a higher output rate than the amplifier output. if you want to use an MP3 player with your stereo you will have to purchase a head unit with a built-in MP3 input or deal with the lower rate of volume.
Aug 13, 2009 | Pioneer DEH-P690UB CD Player
Can't turn volume down!
Go into your sound devices from the control panel. You should be able to raise & lower the volume from there as well as putting the volume icon back into your system tray. Hope this helps.
Jul 08, 2009 | Compaq Armada E500 Notebook
Bass goes off when i turn up the volume
You need to install a heavier gauge wire to your amp and a capacitor. It works fine at low volumes because there is enough wattage from the battery to power the bass output of the amp but at higher volumes the amp does not have enough power.
Heavier gauge wire supplies more poer, and a capacitor stores a reserve of wattage for the amp to use so that it does not run out while blasting your tunes.
Jun 02, 2009 | Fusion FEW12PK Car Subwoofer
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My Philips SBP1100 speaker' volume is not loud enough
Were they ever loud? If they weren't (which is my guess - judging by the picture) is that they are low wattage which essentially means that they are not intended to be loud. They are most likely to be used as a small compact, low-noise speaker for a smal MP3 player where high (club-vloume) wattage/volume is needed. If they used to be loud check the volume control on your laptop and check each and every setting that there is. One stupid little setting could be a big difference. Audio Properties in the control pannel could be helpful but don't mess with those settings in the control pannel unless you are almost positive as to what they are and what they do. You could cause yourself a bigger problem. Remember that most laptop speaker outputs are actually for headphones and are not intended to go super-high as they are designed for headphones and not to hurt ears at high volumes. Hope this helps. If not try checking back with me. Best of luck. Bonne chance!
Mar 09, 2008 | Philips SBP1100/37 Portable Speaker System...
Volume goes full blast when turned up from zero to just a "1" onscreen
I have seen a similar problem. get to design mode (that trick with the remote mute & the set menu button) & look for a data address in the audio section that is set to all (F)s. sorry i can't remember the exact address. you could always just guess just make sure you write down where they are currently set .
Hope this helps.
Jan 25, 2008 | Toshiba 19A26 19" TV
200 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
