Question about Husqvarna Chain Saw 20" Bar
Can not get spring in the kickback lever assembly
How do I replace spring in kickback lever assembly in my husquvarna 455 chainsaw?
  • Husqvarna Master
  • 2,239 Answers
The return spring is not supposed to come out, however, remove the e clip and pull out the pin, the spring has a loop at the an arched leg and a leg with a pig tail. Press the arch leg and the pig tail leg together and push the loop up into the hand guard with the pig tail facing toward what would be the rear of the saw, push it up as far as it will go, push the pin back in and re fit the e clip, the arch leg of the spring should now be resting on the top of the pin if you have done ir correctly, and the tail of the pig tail should be protruding.
Posted on Apr 28, 2014
5 Suggested Answers
  • 16 Answers
SOURCE: fuel line replacement
I recommend remove all fuel from the tank. Remove the hose from tank to carb. take the tube with you, when getting new hose.
Posted on Jan 19, 2009
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
  • 2239 Answers
SOURCE: Hown do you remove the
Start by removing the chain brake/side cover, make sure the brake is off before removing, remove the guide bar and chain, the clutch centre has two cut a ways designed to take a screw driver blade, the clutch is just spun onto the crank with a left hand thread, insert the screw driver into one of the cut a ways parallel with the machine, and strike with a suitable hammer, this will eventually jar the clutch off against the compression of the saw, it may well take a good few strikes, but it will go. There is a workshop tool availabe, with a 19mm nut on the top, and two legs to fit into the clutch centre, so as to fit an impact wrench and jar it off , part no. 502541601
Posted on Mar 16, 2011
Just changed the ring and now can't stop the chain from moving, Is there anything to check besides the carburator?
For the 455 Rancher.
First check the idle speed. It should be 2700 rpm. Clutch engages at around 3800 rpm. If the clutch is engaging below the 3800 then clutch springs need checking and replacing if needed.
If you can't get the idle speed down check for air leaks.
Jan 24, 2015 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you replace clutch on cs 350 echo chain saw
I am guessing what you are calling the clutch band is the anti kickback brake. It is operated by a "lever" in front of the hand grip on the front of the saw. Pull that lever towards the rear of the saw to get more slack in the band.
Jul 31, 2014 | Echo Garden
Pawls don't catch on rancher 455
The starter pawls are held on with small springs. If the springs are broken or installed incorrectly, this can happen. I would suggest replacing the springs and maybe the pawls. Check the recoil assembly to make sure the issue is not with the recoil assembly.
Feb 08, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Pull cord on my chain saw will not recoil
Off hand I would say the recoil spring is broken. they can be a bugger to replace. I would remove the cover and take it to a hasqvarna dealer, and have them replace it.
Dec 29, 2012 | Husqvarna Garden
Chain will not turn when on or off
Sounds like the chain brake may be engaged. You should have a lever that looks somewhat like a handguard on the top of the chainsaw, right in front of the handle you hold the saw with. It should "snap" when you disengage the chain brake by pulling the lever back towards you.
You can find replacement chainsaw parts at PartsBuggy.com.
Sep 15, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Hown do you remove the clutch plate on a Husquvarna 455 Rancher
Mar 16, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Clutch cover wont go back on
Your cover probably won't go back on because the kickback/chain brake is on. Pull the handle on the cover back until you hear a click, the it will go on. As for removing the clutch, you need Poulan tool # 530031112 and an impact witha 3/4 socket. If you're just trying to reset chain break, removing clutch is not necessary, just pull back on handle as I said before.
May 30, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna Chain Saw 20" Bar Logo
114 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
