Loose pipe under front of machine that leaks water loads cant find the place to reonnect it,
Small pipe under front of machine has came of and I dont know where to put it back onto, machine is secondhand.
    Master:
  • Washing Mach... Master
  • 753 Answers
What is the model nuber?
Posted on Mar 30, 2014
  • 3600 Answers
SOURCE: Zanussi front loader leaking
Most likely you have a pump shaft seal leaking you can buy a new pump at this site. You may remove the pump and clean with pool muratic acid, but it is very caustic you would have to put pump in the acid bath in a metal pan that you don't mind using it and it will eat all the organic buildup from the pump. However it may leak worse as the organic material may keep it from leaking too much. So I suggest you use the pump, if you use mueratic acid it is highly toxic so read directions on using it and were air mask and rubber gloves while using it then rinse off with clean water. You should put water hose in the drain pipe and tunrn on the water to test the drain pipe as well. this will make sure the drain pipe is fine. Look at the hoses near the clamps as this is where holes develop on the water pump hoses.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=Zanussi+front+loader
Posted on Sep 05, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
rickead1
  • 1998 Answers
SOURCE: Water is leaking out from under the front part of
have u checked the pump that is located iin the front of the machine? Remove the entire cover of the machine look down in the very front when the cover is removed turn the machine on and you should be able to see exactly where ur leak is coming from your pump is located on the motor small white or grey plastic round like object sometimes it can leak fromthe center of the pump in any case test the machine with the cover off and you willbe able to find the leak hope this helps
Posted on Jul 15, 2010
livewire874
  • 618 Answers
SOURCE: water leaks onto floor from under washing machine
Pull off the front panel and see where water is coming from.
Posted on Nov 22, 2010
  • 127 Answers
SOURCE: leaking water from washer with
It could be as simple as a lose hose clamp, or it could be a cracked water pump. You did not say what brand of washer you have. For most brands you can remove the back cover and inspect the hoses and water pump. You should be able to fix this problem with simple hand tools.
Posted on May 27, 2011
Leaks water only when wasing or draing cycle ubder front of machine
Look for a leaking hose on the pump housing. May be just a loose clamp.
Jun 27, 2017 | LG WM2077CW Laundry XL Front Load...
Hotpoint WMF720 Aquarius+
Hotpoint WMF720 Aquarius washing machine is leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Dec 28, 2012 | Hotpoint Washing Machines
The water level never stops, it just fills till it over flows
if on auto level select water level eg medium or low depending on amount of clothes this sometimes works dont use auto water level. If not check small pipe under touch board on top panel, make sure u unplug mains from plug pipe may be loose its small plastic goes to level sensor on right of board. If not level sensor faulty.
Feb 21, 2011 | Haier HLP21E Top Load Washer
Leaking water onto floor from inside machine
2 common places.1 leak from the pipe/s from the valves to the dispenser box,2 @6 o/clock position in the fold of the door seal is where these models produce a small split.filter not tight.water bubbling over stand pipe when machine pumps out?these machines are usually fairly leak free so might be just one of these things i`ve listed here with luck.
Dec 29, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Leaves in water
Check pipes are not blocked, to do this while you have water in machine,remove outlet pipe from drain, and place into a bowl so it is below the tub.If water does not come out then pipe is blocked. Whichever you need to do the following.
1 unplug machine, and remove the rear panel at the bottom, using a screwdriver.
2 If no water came out from pipe then directly below tub is a black pipe, this will need to be removed using fitting either grips or a screwdriver, depending on what fitting retains pipe to the tub.As you remove the pipe be carefull not to loose the ball inside pipe. This is like a ping pong ball.You can now check pipe.
If you did get waterr out from pipe at stage 1 then remove other end of this pipe, from the pump only. Then tilt machine and view under pump to see what holds it in place. Normally 2 scews. Remove these and lift pump away, be carefull of the 2 wires that go to pump.You can now check pump is clear. If it is then chances are you need a new pump. This will cost around £10.00 but you will need to use the front part from old pump.When refitting ensure pipes are fitted correct and you have no leaks. This is fairly easy to do yourself, just take time and look where screws are fitted to pump casing. I am sure you will do this no problem, so good luck. PS. most shops will charge around £45. if pump is blocked and anything from £45-£60 to fit a pump.so it is worth doing it yourself.Also you dont need a genuine hotpoint pump, just ask for an Askol pump.
Mar 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Someone put washing powder in machine
First unplug the machine; open up behind to see if any of the hoses have come loose, tighten. Another place to look is the top of the machine where the water comes in, you hv to open the top to see if some hose there has come loose. Refit carefully. It is even possible that it leaks from where your filter is. Three places to check in all.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Beko wmb1ow leaking cant see where from
Have a look at the hose that runs from the dispenser to the tub front.
They can leak when they rub against the shell.
Hope that helps
Nov 25, 2008 | Zanussi ZWF1430W Front Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water leaking from bottom of washer
you need to fill it up a little then switch it off. tilt it backwards and if it hasnt got a base you should be able to see where the water is coming out of. check the bottom hose and around the element location.
Jun 23, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
